Results 1 to 3 of 3
Thread: Shared Coordinates from Revit to Navisworks
    October 16, 2016
    385
    10:15 AM
    Hello all,
    I have a Revit georeferencing model , I export to NWC with Shared Coordinates.
    In Navisworks I have also sets Shared Coordinates for the Revit files and Dispay Units: meters.
    When I select the model in Navisworks > Units and Transform > the units are in Feets (why?) but the coordinates are correct (if I try to change the Units in meters , the coordinates change) - Only the rotation is different but if I sum the Rotation in Navs + Rotation in Revit it gives me 360...So I suppose that it is correct..
    When I go Output : Google Earth KML, In the Google Earth Coordinates I have the coordinates that I have given in Revit in the Location Panel
    And in the Navisworks origin I have 0,0,0 . Is it correct? I was waiting to have the coordinates that exist in the Units and Transform dialog box.
    My purpose is to export the model in Google maps..
    February 9, 2017
    2
    05:15 PM
    Output kml function doesn’t work- better to output and locate visually
    October 16, 2016
    385
    10:15 AM
    Quote Originally Posted by Gedward View Post
    Could you please give more details for what I need to do?
    Thank you!
  1. Revit Shared Coordinates and Linking
    By kleindirk in forum Architecture and General Revit Questions
    Last Post: August 9th, 2017, 01:52 PM
  2. revit to dwg: exporting sheets with shared coordinates - possible ???
    By kunster in forum Architecture and General Revit Questions
    Last Post: May 14th, 2017, 10:49 AM
  3. Revit, Navisworks, IFC and Shared Coordinates
    By Exar Kun in forum Architecture and General Revit Questions
    Last Post: June 10th, 2016, 05:07 AM
  4. Revit OpEd: Shared Coordinates and Worksets
    Last Post: November 20th, 2013, 09:15 PM
  5. What Revit Wants: Point Clouds and Shared Coordinates
    By luke.johnson in forum Blog Feeds
    Last Post: August 16th, 2013, 03:15 AM
