Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By danbush
  • 1 Post By danbush
Thread: Scrum in BIM-Projects
    November 18, 2013
    Germany
    89
    03:17 AM
    Hello BIM-Pros,
    In the field, i hear sometimes the word "scrum" does anybody know how to use it in BIM-Projects. Is there any usefull literature? regarding this topic.
    I use some diagramms for clash-matrix... Does anybody has other workflows "mindsets" ....
    Thank you for any advice
    Andreas
    Attached Thumbnails Attached Thumbnails Scrum in BIM-Projects-2018-09-07_10h26_35.png
    Member mjajansen's Avatar
    December 26, 2011
    147
    03:17 AM
    I know what scrum is, and in know what bim is, but that graph doesn't make any sense to me.
    Member HansLammerts's Avatar
    April 22, 2011
    430
    03:17 AM
    Your scrumming matrix look like clashing models
    February 5, 2012
    45
    02:17 AM
    Scrum is a part of agile software development. Projects are delivered in chunks made up of a ready to use function (start a new project, enter data and save it; print a report; etc.). The delivered value is produced in a dedicated period of time called a sprint.
    In a sense, the traditional schematic, SD and. CD passes are like sprints. Similarly, fast track delivery files the same idea.
    I think there are a lot of applicable processes between the two industries (which is probably why software has started using the term 'Architect'. I wish I understood how they get away with that given the strict laws regarding the use of the word).
    At the the end of the day, having a process is better than not having one. Wherever you get your inspiration, be consistent and clear about what is expected and follow through.
    Sent from my iPad using Tapatalk
    Andres Franco likes this.
    May 18, 2011
    Calgary, AB
    368
    07:17 PM
    You'll want to dig into Agile Project Management.
    "Scrum is an agile method of iterative and incremental product delivery that uses frequent feedback and collaborative decision making."
    https://www.pmi.org/learning/library...ent-scrum-6269
    I haven't done an exhaustive search, but I've yet to see any real case studies of effectively using Agile in the AEC industry.
    As much as we like to think the industry is moving at a blistering pace, I see it more as a lazy stroll on a Sunday afternoon.
    February 5, 2012
    45
    02:17 AM
    I experimented with it over the course of a few projects but in the end it was not a good "one for one" application.
    As an example, during DD, I did sprints to gather the requirements and document and specify all casework and millwork; doors ; windows, etc in the project. This delivered something of "value" but in the end, it was not useful without the rest of the building.
    In software, what you build IS the final product while we are building a virtual copy of the reality someone else will build in the future. So no, not a good direct application.
    cheinaranta likes this.
  1. Revit Projects
    By sfmelegy in forum MEP - General
    Last Post: March 21st, 2017, 05:53 AM
  2. Marine Projects in RST
    By alexo4141 in forum Structure - General Questions
    Last Post: November 16th, 2012, 05:53 PM
  3. rsn.ini is present but no projects
    By ptranberg in forum Worksharing, Revit Server & C4R
    Last Post: August 20th, 2012, 06:44 PM
  4. Scaling between projects
    By Raiju in forum Architecture and General Revit Questions
    Last Post: January 29th, 2012, 09:31 AM
  5. Revit projects
    By bangobeat in forum Out There
    Last Post: July 5th, 2011, 09:04 PM
