Results 1 to 7 of 7
Thread: Some views not showing i Autocad from Revit export.
    March 19, 2018
    Oslo, Norway
    4
    02:32 PM
    I'm trying to export a sheet to dwg from Revit.
    Some of my detail views on the sheet will not show in paperspace. The viewport is showing, but the content (detail) is not.
    I've got a total of 8 details on this sheet, but only 5 showing.
    In modelspace, everything appears.
    Does anyone have a solution for this?
    Thanks.
    June 21, 2012
    Tours, France
    894
    02:32 PM
    Quote Originally Posted by Jsveinson View Post
    Thanks.
    What are your export settings please?
    March 19, 2018
    Oslo, Norway
    4
    02:32 PM
    Hopefully, this is what your asking for.
    Attached Thumbnails Attached Thumbnails Some views not showing i Autocad from Revit export.-2018-04-17-15_24_59-modify-dwg_dxf-export-setup.png   Some views not showing i Autocad from Revit export.-2018-04-17-15_25_22-modify-dwg_dxf-export-setup.png
    June 21, 2012
    Tours, France
    894
    02:32 PM
    yes I was talking about that, sadly I've noticed that you've already unchecked the default export options, did you already check the dialog box that follows? I mean after validate you'll have another dialog box that allows you to export the views in the sheet as external references, I bet that it can be that!!
    March 19, 2018
    Oslo, Norway
    4
    02:32 PM
    Tried both options and still no luck.
    A colleague of mine suggested it might be because the three details not showing were projected upwards. May this be the cause?
    Attached Thumbnails Attached Thumbnails Some views not showing i Autocad from Revit export.-2018-04-17-15_39_42-autodesk-revit-2018.3-%5Bsheet_-000-prosjektinformasjon-raadhusgata5_rib.png
    June 21, 2012
    Tours, France
    894
    02:32 PM
    Honestly I don't think so! but for the sake of this thread we need to check all options, so another question that happens for all your Sheets/views?
    March 19, 2018
    Oslo, Norway
    4
    02:32 PM
    No, this is the first time it has happened.
  1. URGENT HELP! revit export to autocad problem!
    By JiaQing in forum Architecture and General Revit Questions
    Last Post: July 7th, 2015, 07:17 AM
  2. Linked AutoCAD hatch patterns not showing up in Revit prints...
    By kcaparella in forum Architecture and General Revit Questions
    Last Post: January 18th, 2013, 08:54 PM
  3. Replies: 5
    Last Post: June 1st, 2012, 04:15 PM
  4. How i can save setting of export revit to autocad ????!
    Last Post: May 7th, 2012, 02:13 PM
  5. Revit to Autocad export - issues
    By rohini in forum Architecture and General Revit Questions
    Last Post: October 17th, 2011, 01:05 PM
