Results 1 to 5 of 5
Thread: Column Area is Wrong
    Moderator Drew's Avatar
    December 9, 2010
    Perth, Western Australia
    683
    05:32 PM
    HI all,
    I noticed something today when looking through my Navisworks file, the areas for the columns seems to be wrong.
    The image below show a 500mm x 500mm x 5000mm column, so by my calculation the surface area should be 10.50m2
    Single side (.5m x 5m = 2.5m2)
    4 sides (2.5m2 x 4 = 10m2)
    Top (.5 x .5 = 0.25m2)
    Base (.5 x .5 = 0.25m2)
    10 + .25 + .25 = 10.5m2
    Navisworks is telling me that the Area is half of that ie 5.25m2
    Have I missed something here? Why would this be?
    Coeur d Alene, ID
    4,318
    02:32 AM
    SA=2 x (l x w + l x h + w x h)
    SA=2 x (500 x 500 + 500 x 5000 + 500 x 5000)
    SA=2 x 2625000
    SA=5250000 square millimeters
    1 mm2 = .000001 m2
    So 5.25 m2 is correct
    Square area is L X W....you multiplied 2L x 2W when figuring your sides.
    EDIT.... Reworking own results above and I get 10.5... grrr
    December 21, 2010
    C.LONDON
    4,231
    10:32 AM
    I make it 10.5m2 like Andrew.
    Coeur d Alene, ID
    4,318
    02:32 AM
    Well....I get 10.5 too. All I can think is Navis is showing the area that is exposed vs the total area.
    December 21, 2010
    C.LONDON
    4,231
    10:32 AM
    No, as in my my paper-maths makes it 10.5m2 - I don't follow your first post's math logic.
  1. Revit 2014: Wall join to Column overides column display
    By MrBIMtastic in forum Architecture and General Revit Questions
    Last Post: June 20th, 2015, 12:09 AM
  2. What's wrong ?
    By nguyenkien in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: April 28th, 2015, 10:44 AM
  3. Revit Extensions placing column base connection at top of column
    By wardley31 in forum Architecture and General Revit Questions
    Last Post: December 4th, 2014, 11:29 AM
