Donate Now Goal amount for this year: 3000 USD, Received: 2285 USD (76%)
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By pivoarch
Thread: Revit Files Coming in Sectioned
    Member pivoarch's Avatar
    March 16, 2011
    Hamilton, NJ
    250
    05:06 PM
    Ok guys, I know I'm probably just missing something stupid here but I'm not that familiar with Navis and Google is not providing me any help. So, when I open my Revit file in Navis it comes in looking sectioned. The Architecture model looks like this:
    I cannot for the life of me figure out why, I tried toggling the section views and unhiding everything. The Structural model comes in looking sectioned in plan.
    Any ideas would be appreciated.
    Thanks in advance.
    Attached Thumbnails Attached Thumbnails Revit Files Coming in Sectioned-sartp-navis.jpg
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,479
    05:06 PM
    Are you exporting from a Revit View with Section Box turned on?
    Whatever View is active when you Export will be what gets exported as is. If the View is cropped, the NWC will be, too.
    March 16, 2011
    Hamilton, NJ
    250
    05:06 PM
    Hey Dave,
    I'm not exporting it at all, just opening the RVT in Revit, I also tried to append the RVT into Revit and Merge it all with the same results.
    I could try exporting a NWF and see if that works better.
    January 17, 2011
    1,894
    05:06 PM
    For the record, always export NWC. You have greater control of the export.
    -TZ
    January 10, 2011
    St Paul, MN
    2,479
    05:06 PM
    Now, that you mention it, Tannar, I remember that you can configure Navis (or is it the Export?) to look for a specific View.
    By default, I think Navis looks for a View with "Navis" in the name, and it if doesn't find that, it uses the default {3D} View.
    No idea which View it uses if it doesn't find either.
    8,825
    05:06 PM
    APpending an RVT will (more often than not) work like a complete bag of ****. I recommend never doing that.
    It ISNT auto-appending the "entire model," when you do that. I believe (as Dave mentioned) it looks for NAVIS in the view name, and if it doesnt find that, it uses whatever 3D View it finds first, or something stupid. Either way, it still exports a VIEW. Since it does thiat, might as well handle your exports manually, lest you end up with views exported that are actually missing things because they were hidden in Revit.
    Member HansLammerts's Avatar
    April 22, 2011
    388
    10:06 PM
    Yes, you have to manually export rvt files. Open export close, open export, close. Progs together work far from great Autodesk ...
    Senior Member Charles Karl's Avatar
    December 6, 2011
    Fairbanks, Alaska
    916
    02:06 PM
    Quote Originally Posted by pivoarch View Post
    Thanks in advance.
    If I am understanding you correctly, you should just click on the Viewpoint tab, then Enable Sectioning. From there you may have to click on Fit Selection to see the sectioning box and Gizmo. If the section box is not aligned with your model, then choose Box under Mode and use the Move and Scale functions as you manipulate the Gizmo to adjust the section box. You can Save Viewpoint after you get to a desired view, then start over again to adjust for your next view to be saved. Hope this helps.
    March 16, 2011
    Hamilton, NJ
    250
    05:06 PM
    Thanks for the reply Charles, exporting the NWS file from Revit instead of opening the Revit file in Navis solved the problem for me. I'll try your solution as well just for science sake.
    CADiva likes this.
  1. Revit LT 2016 - When is it coming?
    By d.stairmand in forum Architecture and General Revit Questions
    Last Post: May 6th, 2015, 10:42 AM
  2. What Revit Wants: A Change is Coming...
    By luke.johnson in forum Blog Feeds
    Last Post: January 27th, 2014, 09:45 AM
  3. Revit Kid: Major Revizto Update - Coming Soon...
    By The Revit Kid in forum Blog Feeds
    Last Post: November 21st, 2013, 02:15 PM
  4. Revit LT is coming
    By Exar Kun in forum Out There
    Last Post: March 13th, 2012, 04:58 PM
  5. Revit OpEd: The Extensions are Coming
    By Blog Fetcher in forum Blog Feeds
    Last Post: June 22nd, 2011, 02:40 AM
