Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By snowyweston
  • 1 Post By koolair
Thread: Revit Pipes in Navisworks
    Member koolair's Avatar
    July 31, 2014
    186
    08:20 AM
    For some reason, pipes are displaying their material properties. Copper lines are showing as copper, cast iron is black, and my Appearance Profiler isn't able to override that.
    Also, I don't want to see grassy green roofs, textured brick, etc. but these are all showing too.
    Has anyone encountered/figured this out before? I've seen this happen to someone else.
    EDIT: Never mind, I just changed the Viewpoint mode to shaded.
    December 21, 2010
    C.LONDON
    4,212
    01:20 PM
    Quote Originally Posted by koolair View Post
    What, changing the visual appearance to Shaded (as opposed to Full Render)?
    No, I would never have thought of that.
    [sarcasm-mode-off]
    I dream of the day when I can complain about MEP models with (correct) materials... Consider yourself fortunate.
    [/sarcasm-mode-off]
    koolair likes this.
    December 21, 2010
    C.LONDON
    4,212
    01:20 PM
    Always a pleasure!
    July 31, 2014
    186
    08:20 AM
    Always a pleasure!
    Sorry I didn't see your post snowy. I stayed on the OP and went searching, then when I found it I switched tabs back to the forum to delete, but since you can't delete, I just edited. Thanks for chiming in though. Trust me if I saw your post I wouldn't have ignored it. Cheers,
    snowyweston likes this.
  1. Replies: 0
    Last Post: April 24th, 2016, 02:15 AM
  2. Replies: 2
    Last Post: November 12th, 2015, 03:15 PM
  3. How to annotate parallel pipes in revit
    By bluster in forum MEP - General
    Last Post: July 17th, 2015, 04:27 PM
  4. Replies: 8
    Last Post: November 8th, 2013, 09:07 PM
  5. Drawing 3d Pipes in Revit Architecture
    By rickbern in forum Architecture and General Revit Questions
    Last Post: August 29th, 2011, 10:30 PM
