Results 1 to 7 of 7
Like Tree6Likes
  • 1 Post By tzframpton
  • 3 Post By NavisBro
  • 1 Post By NavisBro
Thread: Navisworks | Editable Shortcuts?
    January 17, 2011
    1,963
    02:13 AM
    Question Navisworks | Editable Shortcuts?
    Is it possible to edit shortcuts to keystrokes or similar in Navis? Specifically what I'm trying to do is preset a Transparency Override to operate much like the keyboard shortcut for Hide (Ctrl+H). It'd be nice to preset 60% transparency as a F-key or keystroke combo. For instance, if I could set Ctrl+Q to set the transparency of the selected object(s) to 60% transparency, this would reduce the right-click > Override Item > Override Transparency > {Set Value} > Click Okay to a workflow that is at the "speed of conversation".
    Any ideas? Thanks!!
    -TZ
    HansLammerts likes this.
    April 13, 2015
    36
    03:13 AM
    You can modify the RoamerCommands (C:\Program Files\Autodesk\Navisworks Manage 2016\Layout) - best I could do was get the Override Transparency window to pop up with the Ctrl+Q shortcut.
    You'll need to remove the line <Command ID="RoamerGUI_EDIT_OVERRIDE_TRANSPARENCY" />
    and add the following - I added it below the <Command ID="RoamerGUI_MODE_SELECT_BOX"> command.
    <Command ID="RoamerGUI_EDIT_OVERRIDE_TRANSPARENCY">
    <Shortcut>Ctrl+Q</Shortcut>
    <Toggle>true</Toggle>
    <Accelerator>Q</Accelerator>
    </Command>
    See the attached screenshot
    ALSO - Make sure you save an unedited version of your RoamerCommands as Navisworks will NOT open if you mess up the syntax.
    Attached Thumbnails Attached Thumbnails Navisworks | Editable Shortcuts?-2016-10-18_9-36-17.png
    January 17, 2011
    1,963
    02:13 AM
    VERY good tip Mason. Although not entirely complete for my own standards, this still slices through the right-click middle man scenario and brings up the slider bar immediately, which is an alternative I'm okay with.
    Many thanks on this. If we ever cross paths with some mutual friends, I'll buy you a beer on this one.
    -TZ
    Andres Franco likes this.
    January 17, 2011
    1,963
    02:13 AM
    For the record, I didn't move it up to the top of the list. I kept it in the same line it was currently in and everything works just fine. Is there a reason you moved <Command ID="RoamerGUI_EDIT_OVERRIDE_TRANSPARENCY"> up to the top?
    April 13, 2015
    36
    03:13 AM
    Just to separate the commands that have keyboard shortcuts from those that do not.
    Not really necessary - just preference.
    tzframpton likes this.
    January 17, 2011
    1,963
    02:13 AM
    Quote Originally Posted by NavisBro View Post
    Gotcha, thanks for clarifying. Again, many thanks. This already is helping my workflow.
    -TZ
    October 18, 2018
    1
    01:43 PM
    Hi Mason,
    That was a good tip. I need a small help from you.
    I have created a button using API, but i don't know how to add shortcut for the button.
    can you help me on creating a shortcut for my customized button??
    Thanks!
  1. Replies: 0
    Last Post: October 28th, 2014, 12:45 PM
  2. families not editable
    By bertram in forum Architecture and General Revit Questions
    Last Post: December 27th, 2012, 06:11 AM
  3. Delete Non editable workset??
    By Drew in forum Architecture - Family Creation
    Last Post: February 21st, 2012, 12:48 AM
  4. How to add Category Parameters to be editable?
    By Yan Naing Bo in forum Structure - General Questions
    Last Post: September 16th, 2011, 08:55 AM
  5. Non-Editable Workset:
    By Jj Mac in forum Worksharing, Revit Server & C4R
    Last Post: April 8th, 2011, 01:58 PM
