Results 1 to 3 of 3
Thread: "Opening Direction Definition" in Solibri Model Checker - What defines it?
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    334
    08:45 AM
    I see that most of the posts in here are about NavisWorks, but i'll try my luck anyway:
    I'm really scratching my head, trying to figure out what gives a Revit door it's "Opening Direction Definition" in Solibri Model Checker. (via IFC file format)
    So far i've tested my way through, to this:
    A door family needs to have a quarter circle symbolic line, type Plan Swing. Straight lines do not work, has to be a circle
    Does anyone here have any information on this they'd like to share? Other rules? Do's and don'ts?
    We're having problems with several door families, that either has two swing directions ( where there should be one) or none at all ( and some times we want two... ), in Solibri. Gives us all kind of headaches in our clash detection.
    Attached Thumbnails Attached Thumbnails "Opening Direction Definition" in Solibri Model Checker - What defines it?-capture.png   "Opening Direction Definition" in Solibri Model Checker - What defines it?-2.png   "Opening Direction Definition" in Solibri Model Checker - What defines it?-3.png
    June 29, 2011
    Denmark
    76
    10:45 AM
    Hej Tue,
    In the Type "Operation" field under Ifc Propeterties of the door, write fitting enum from this list: IFC4 Documentation
    Left/Right only have to be correct in the family editor. The exporter is written such, that Revit will change it around correctly on export.
    February 6, 2012
    334
    08:45 AM
    Thanks, soender, that brought us a lot further.
  1. Replies: 0
    Last Post: April 28th, 2015, 11:15 AM
  2. Revit and Solibri Modell Checker
    By Nina1985 in forum Coordination Tools
    Last Post: July 18th, 2014, 08:50 AM
  3. Rebar Diameter symbol "Ø" is Showing as "0" in Revit 2014
    By Shefypattambi in forum Architecture and General Revit Questions
    Last Post: July 14th, 2014, 01:49 PM
  4. What is "Direction Line" in beam systems?
    By gpktm in forum Structure - General Questions
    Last Post: February 3rd, 2014, 08:16 AM
  5. Hw to disattach part of model in "Model in-placel" mode
    By Xawier in forum Architecture - Family Creation
    Last Post: February 20th, 2013, 04:33 PM
