Results 1 to 6 of 6
Thread: Rotate IFC model
    June 13, 2014
    1
    12:27 AM
    Rotate IFC model
    I open the IFC model in Revit, but the orientation is wrong, I need to rotate the model from horizontal to vertical, but I can not.
    I try to rotate in elevation view, but I get the error messaje.
    September 7, 2011
    1
    08:27 PM
    Quote Originally Posted by Nirea View Post
    I have the same problem, but haven't seen a solution.
    August 29, 2013
    19
    12:27 AM
    same thing here.
    we got a new IFC from fabricator and while trying to replace it found that it comes rotated up right!
    April 6, 2017
    2
    08:27 PM
    I have the same issue, anyone know of any tools that allow you to quickly edit/rotate an IFC without having to use Revit?
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    317
    01:27 AM
    I have the same problem currently, with a model exported from SolidWorks.
    I found this:
    https://www.gsc-3d.com/articles/2016...tem-solidworks
    -And also, i was able to rotate the model in Navisworks. But not export from Navis, only as their native format, NWD. I was able to link NWD into Revit 2018, not 2017. Which is infortunate, because the project is in 2017. Hrmphh!
    Senior Member ekkonap's Avatar
    May 23, 2011
    Netherlands
    575
    01:27 AM
    A very crude solution that has worked for small models is to edit the ifc with a text editor, and swap the positive and negative X value of every IfcCartesianPoint, effectively mirroring the model. There is also at least one coordinate system defined in an IFC file (could be more then one) where you can rotate the entire model. Never tested in building scale though, YMMV.
    Keep in mind that derivatives, like any corresponding BCF needs to be translated accordingly.
  1. help in how to rotate component or family model in 3d ?
    Last Post: December 13th, 2013, 03:00 AM
  2. how to rotate this?
    By minuj23 in forum Structure - General Questions
    Last Post: July 9th, 2013, 03:18 PM
  3. To rotate sheets or to rotate views
    By anthonyB in forum Architecture and General Revit Questions
    Last Post: April 19th, 2013, 03:19 AM
  4. Replies: 0
    Last Post: November 23rd, 2011, 12:45 AM
  5. any idea on how to rotate Generic model in place from horizontal into vertical?
    Last Post: November 9th, 2011, 03:02 AM
