Hello fellow Revit users
I want to present you revitAddinDisabler: an external program to quickly enable or disable Revit addins. You can enable or disable them one by one or all of them per Revit version.
Download: https://github.com/infeeeee/revitAdd...eleases/latest
Don't forget to run as admin!
Documentation and source code: https://github.com/infeeeee/revitAddinDisabler
I created this program, because the other standalone program with the same functionality (stantec addin manager) didn't work for me stable enough, sometimes it messed up addin files. My program is 100% compatible, so if you enable/disable with one of them it should show up correctly with the other.
If you found any problems please open an issue on github.
