Results 1 to 1 of 1
Thread: Revit Add in Coding question/help
    April 23, 2014
    79
    01:15 AM
    I have the attached file which is an add in for custom pipe flow rate calculation. However the formula used is wrong, I have tried changing it myself, however when I go to "build" the project it fials, and being a coding novice I cannot figure out why, could somebody please help.
    Their are three "servers"
    Plumbing Fixture Flow server
    Plumbing Fixture Flow server TE
    Plumbing Fixture Flow serverTE(NoSE)
    In all three the dFlow calcualtion needs changing to
    dFlow = 0.532*(Fixture Units ^ 0.7)
    Thanks!
    Attached Files Attached Files
  1. Building Coder: Five Secrets of Revit API Coding
    Last Post: September 10th, 2018, 09:15 AM
  2. Replies: 0
    Last Post: January 31st, 2015, 08:45 PM
  3. Replies: 0
    Last Post: October 7th, 2012, 05:15 AM
  4. Replies: 0
    Last Post: September 29th, 2012, 05:47 AM
  5. Revit ST: Unlocking BIM Data / BIM Coding Standard
    By Revit ST in forum Blog Feeds
    Last Post: December 12th, 2011, 02:45 PM
