Donate Now Goal amount for this year: 3000 USD, Received: 2285 USD (76%)
Results 1 to 4 of 4
Thread: AsiaSW - RoomMass for Autodesk Revit
    August 22, 2012
    18
    03:23 AM
    Lightbulb AsiaSW - RoomMass for Autodesk Revit
    Simple and useful
    Do you need to automatically create mass elements from a room’s objects in your project?
    Create geometry from room’s objects so you can visualize it volume in 3D view?
    RoomMass is the right solution.
    RoomMass for Autodesk® Revit® provides a tool to automatically create mass elements (mesh geometry) from a room’s objects so you can visualize the room’s volume in 3D View.
    Watch a video demo:
    https://screencast.autodesk.com/Main...0-96af91c68450
    More information on Autodesk Revit Exchange Apps Store http://apps.exchange.autodesk.com
    AsiaSW - RoomMass for Autodesk Revit-img1.jpgAsiaSW - RoomMass for Autodesk Revit-cattura3.pngAsiaSW - RoomMass for Autodesk Revit-cattura33.png
    August 22, 2012
    18
    03:23 AM
    Lightbulb RoomMass for Autodesk Revit 2014-2015 New Release
    Released new release for RoomMass for Autodesk Revit 2015.0.16.20430, we have corrects some bugs an added this features:
    1. Support for Autodesk Revit 2014
    2. New options:
      • (Tessellate/Don't Tessellate) if you want to tessellate curve room's profile or not
      • (Mass/Masses) if you want generate a single mass to contain all rooms selected or single mass for every rooms selected.
      • (Tag/No Tag) if you want to tag automatically every mass with room name/ID that have generated it.
      • (Room 2D) if your project is configured in Area and Volume Computations to Areas only (faster), you can extrude each rooms profile. Height is determined from Upper Limit and Limit Offset parameters of each room.
      • (Room 3D) if your project is configured in Area and Volume Computations to Areas and Volumes, you can choose to create extrude masses like previous option ( Room 2D), or to generate mass elements (mesh geometry) from each room volume.
    If you select Room 2D, option Tessellate and Masses are disabled
    If your project is configured in Area and Volume Computations to Areas only (faster), Room 3D is disabled.
    For more information:
    RoomMass | Autodesk Revit | Autodesk Exchange Apps
    Free of charge if you have previous release.
    Enjoy!!
    August 22, 2012
    18
    03:23 AM
    Released new version RoomMass for Autodesk Revit 2016 2016.2.1.24014, added compatibility with Autodesk Revit 2016.
    August 22, 2012
    18
    03:23 AM
    Released new version RoomMass for Autodesk Revit 2017 2017.3.5.40875, added compatibility with Autodesk Revit 2017.
  1. AsiaSW - PowerMeasure for Revit
    By asiasw in forum Commercial & Free Add-Ins/Extensions
    Last Post: April 19th, 2016, 07:51 PM
  2. AsiaSW - PowerSheets for Autodesk Revit
    Last Post: April 19th, 2016, 07:30 PM
  3. Replies: 0
    Last Post: June 24th, 2013, 11:15 AM
  4. Replies: 0
    Last Post: April 1st, 2012, 02:45 AM
  5. Replies: 0
    Last Post: August 5th, 2011, 11:11 AM
Tags for this Thread
