It was found that Revit loads and bounds bad shared parameters from the associated SPF. Here is such an example. # This is a Revit shared parameter file. # Do not edit manually. *META VERSION MINVERSION META 2 1 *GROUP ID NAME GROUP 1 TEST *PARAM GUID NAME DATATYPE DATACATEGORY...
