The command Settings for Project Parameter Tools will pop up the following dialog. DescriptionForNoneSharedPPsInExportedSPF: specifies what description to use for none shared ProjectParameters with auto-generated GUIDs in the SPF.txt. GenerateAutoGUIDsForNoneSharedPPsWhenExporting: specifies if to automatically generate GUIDs for none shared Project Parameters in the Export tools. GUIDPlaceHolderForNonSharedPPsInExportedSPF: specifies what place holder...
