Ever have someone want to use Copy to Clipboard and then Paste Aligned to create a new level? I haven't but it is technically possible to create a new level by doing it.
Example 1:
Open an Elevation view
Select Level 2
Use Copy to Clipboard
Open the floor plane for Level 2
Use Paste Aligned > Aligned to Same Place
Result - A new level but on top of Level 2.
Example 2:
Select Level 2
Use Paste Aligned > > Aligned to Current View
Result - A new level but using the same elevation offset (distance) as Level 2
Example 3:
Start with a new template
Create a new level with the Level tool
Adjust all three levels so they are each 12'-0" apart
Select Level 3
Open the floor plane for Level 3
Result - A new level but using the same elevation offset (distance) as Level 3
You can also place a new one with Paste Aligned > Aligned to Selected Levels, choose the appropriate level in the dialog that appears.
It isn't the first thing I'd think of to create a new level, but it IS possible.
