This update applies to Autodesk 360 desktop companion if your version is 4.0.27.1 to 4.0.32.100.
To see your version of your 360 desktop companion: log into Autodesk 360, right-click on the system tray icon and select preferences (the version is listed in this dialog).
Fixes in this live update include but are not limited to:
  • Better Inventor file and folder structure support
  • Customer Error Reporting Support
  • Performance fixes
  • Stability Improvements
Please close all applications before installing and restart after installing. Be sure to install the correct update (32-bit or 64-bit) for your operating system.
More information about Autodesk 360 desktop companion can be found at the Autodesk 360 FAQ.
via
Autodesk - AutoCAD Civil 3D Services & Support - Live Update 1 for Autodesk 360 desktop companion
