Donate Now Goal amount for this year: 3000 USD, Received: 2340 USD (78%)
Results 1 to 5 of 5
Thread: problems with room bounding, problems with gbxml export
    August 16, 2012
    5
    09:41 AM
    Post problems with room bounding, problems with gbxml export
    I am having problem with the room bounding, in the level 0 it seems fine, but the level 1 rooms are not showing any heights and room bounding and tag are not showing up in the level 1 view port as well and also the bounding elements from the level 0 are active for the level 1 room bounding, and one other thing when i export it to gbxml for the ecotect nothing gets exported.
    if is at fallowing link
    https://rapidshare.com/files/2029174767/final rivet model112.rvt
    please help
    Regards,
    Zohaib Ali Kalani.
    Attached Files Attached Files
    August 16, 2012
    5
    09:41 AM
    copy the whole link
    https://rapidshare.com/#!download|93...2.rvt|6852|0|0
    and paste it in browser to download the file and paste it in browser to download the file
    Forum Addict
    January 27, 2011
    1,973
    06:41 PM
    Your Computation Height needs to be set to something other than 0 in this file to get the rooms working on Level 1 - see image. I used 1000 and it worked fine. You also need to place rooms a plan that has the correct associated Level (ie. Level 1 rooms always get placed in a Level 1 Plan etc)
    August 16, 2012
    5
    09:41 AM
    Hello again,
    I have fixed that problem but there was another thing i wanted to ask was that when i import my revit gbxml model into ecotect I get this error and nothing gets imported any idea about this :
    WARNING: IFC support is only at beta stage in this release. Whilst detailed geometry should import, ifcSpace data and complex curves may not transform correctly.
    thanks............
    August 16, 2012
    5
    09:41 AM
    Hi, i am getting this warning when i import a gbxml file from revit to ecotect
    any idea whats the problem and how it can be solved.
    zohiab ali kalani.
  1. Room bounding is not working in last floor!
    Last Post: March 17th, 2013, 09:54 AM
  2. Replies: 0
    Last Post: May 21st, 2012, 02:45 AM
  3. MEP export in GBXML
    By fpebble in forum MEP - General
    Last Post: March 30th, 2012, 09:49 PM
  4. Export Materials in fbx to 3dsMax problems
    By Ian.Kidston in forum Rendering and Gallery
    Last Post: October 16th, 2011, 08:54 AM
  5. Room bounding offset or smth?
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: May 24th, 2011, 09:09 AM
