Page 1 of 5 12345 LastLast
Results 1 to 10 of 42
Like Tree2Likes
Thread: I need Best Practice Advice for sharing the model with consultants
    Senior Member Charles Karl's Avatar
    December 6, 2011
    Fairbanks, Alaska
    973
    03:50 AM
    Currrently we will use our ftp to post the model for our consultants.
    What is 'Best Practice' when preparing the model.rvt for sharing with consultants? Should I purge all families, sheets, views,....what should I jettison and what should I keep?
    -Chuck
    9,907
    06:50 AM
    Keep everything, dont change a thing, upload, and keep on truckin.
    dzatto and AHutchinson like this.
    December 6, 2011
    Fairbanks, Alaska
    973
    03:50 AM
    Thanks Aaron, I'll send out as is,...I did however, create an additional title block without stamps, then purged the title block with stamps from the file to be posted.
    9,907
    06:50 AM
    Quote Originally Posted by Charles Karl View Post
    Gotcha. We dont keep those in there, but yeah... Would probably take those out.
    December 21, 2010
    C.LONDON
    4,343
    11:50 AM
    "Stamps" as in company titleblocks? To prevent others printing drawings from the model I presume?
    Member AHutchinson's Avatar
    September 19, 2011
    Spokane, WA
    232
    03:50 AM
    I'd assume that its the security of having the architects stamp floating around, possible even with a signature, which is why I link it in once and copy to selected sheets, then after printing and making sure that everything is fine, I can manage links and remove.
    Junior Member jason.karam's Avatar
    July 9, 2012
    Portland, OR
    27
    04:50 AM
    We also have our stamps (and some digital signatures) in our title block. Purging them all out then uploading the file would be the best idea. Don't want those stamps circulating... i've forgotten to purge them out of cad files before...:s
    December 6, 2011
    Fairbanks, Alaska
    973
    03:50 AM
    I set up a yes/no parameter for 3 different architects stamps using an annotation family, inserted in the title block, one over the top of the other. Visibility is controlled per sheet by checking or unchecking a box in the properties pallet in the catagory of 'Other'
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,230
    06:50 AM
    Why worry about the seal, as long as it doesn't have a digital signature? I can easily recreate your seal from a hard copy if I really wanted it. The seal is worthless without the signature.
    May 18, 2011
    Calgary, AB
    378
    05:50 AM
    I use image files of the stamps with signatures.
    Get it lined up on one titleblock, copy and then paste using "aligned to selected views" and select all the sheets I want.
    Pdf the set.
    Then use Manage images and delete the image.
    Case put out a free add-in that will delete your sheets, views and revit links (I think it removes the cad links as well)
  1. Sharing Our Title Block With Consultants - Best Practice?
    Last Post: June 16th, 2012, 10:58 PM
  2. Need Best Practice Advice for Rooms
    Last Post: March 23rd, 2012, 04:57 PM
  3. Need Best Practice Advice for the use of Split Face
    Last Post: March 21st, 2012, 01:53 PM
  4. RFO Blog: Sharing your model: GET OVER IT PEOPLE
    By RFO Blog in forum Blog Feeds
    Last Post: February 3rd, 2012, 02:15 AM
  5. sharing the model
    Last Post: November 7th, 2011, 05:28 PM
