Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Symbols in Revit text
    December 12, 2010
    New York
    322
    08:50 PM
    Is there any possibility to introduce symbols (like "fi" <diameter), or "+-") in the text editor in Revit?
    I've tried with the Character Map, but when I copy the "fi" symbol, Revit shows me "f".
    United States
    1,634
    10:50 AM
    Hi lucis29,
    If I'm understanding you correctly, you should be able to use any kind of text symbol in the text editor. Revit uses TrueType fonts, so it shouldn't be any different. Make sure that the font you're using for your text in Revit matches the same font your copying the symbol from in Character Map. Let us know if that answers the question or not.
    (I moved this thread here because you're looking for an answer, and the forum "Tutorials / Tips & Tricks is reserved for posting Tutorials and Tips & Tricks - info you already know and want to share with others)
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,567
    10:50 AM
    Here is some more info to add to iru's post
    http://tlt.its.psu.edu/suggestions/i...s/charmap.html
    You can also access the Character Map thru the Start > Run > type "charmap"
    Attached Files Attached Files
    Moderator mark b's Avatar
    NSW Australia
    1,430
    03:50 AM
    Thanks Alex been looking for a table like this for years.
    December 8, 2010
    Northern California
    3,567
    10:50 AM
    my pleasure
    Administrator Ian.Kidston's Avatar
    Melbourne, Australia
    1,145
    03:50 AM
    Thanks Alex,
    Two thumbs up from me
    Cheers
    United States
    1,634
    10:50 AM
    Alex, that's great! The greatest thing about it is that it tells you how to enter the codes... for years I never could get the codes to work, and I just spent another five minutes trying to get them to work, until I noticed the part about using the NUMERIC KEYPAD with NUM LOCK on!
    edit: However, does it work in Revit? Seems like Revit is trying to initiate keyboard shortcuts?
    December 12, 2010
    New York
    322
    08:50 PM
    Quote Originally Posted by iru69 View Post
    Hi lucis29,
    You are right. I haven't payed attention to the font, so I was copying ("Symbol") into "Arial"
    As a matter of fact, I'm using Revit Structure, but I've made the thread here, supposing that this was the part for General Revit.
    United States
    1,634
    10:50 AM
    Hi lucis29, glad you got it figured out.
    About the correct forum to post in for something like that - great point! For the time being, "Architecture-General" seems like a good catch-all if it's not specific to structural or MEP and doesn't fit in any of the other sub-forums.
    1
    12:50 PM
    How about Super or Sub Script within Revit Labels?
    How about handling the Super or Subscript effect within labels? See attached image for example. Is this possible?
    Thanks - Dave
  1. Revit and Text
    By Alex Cunningham in forum Tutorials, Tips & Tricks
    Last Post: June 3rd, 2015, 07:10 AM
  2. Welding Symbols?
    Last Post: May 31st, 2011, 12:37 PM
  3. Adding symbols to a text note
    By soboyle in forum Architecture and General Revit Questions
    Last Post: April 22nd, 2011, 06:31 PM
  4. Symbols won't budge.
    By Gabriel Black in forum MEP - Family Creation
    Last Post: April 12th, 2011, 01:57 PM
