Results 1 to 6 of 6
Thread: Curtainwall System vs Curtain System
    September 26, 2011
    119
    03:59 AM
    If you go to 'home', there is a 'Curtain system' and 'Curtain wall System' under wall catagories.
    have you guys have any Idea difference between these two?
    It seems like Curtain system is exact same with less modification options than Curtain wall system. did I get this right?
    then why they even have this options for?
    St. Louis, MO
    1,954
    06:59 AM
    One difference is that only Curtain Systems can be applied to the face of a Mass, as I understand it.
    September 26, 2011
    119
    03:59 AM
    ummm
    I just applied the 'Curtain wall System' to face of Massing by using 'Wall by Face'.
    St. Louis, MO
    1,954
    06:59 AM
    Curtain Systems can be attached to an irregular Mass face. Curtain Walls cannot. see attached.
    Attached Thumbnails Attached Thumbnails Curtainwall System vs Curtain System-curtain-system.jpg   Curtainwall System vs Curtain System-curtain-wall.jpg
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    333
    01:59 PM
    Curtain Systems:
    -Can be applied to non-plumb faces of a mass
    -Can only contain System panels (System family)
    -Will form a curve by approximating it with straight segments.
    Curtain Wall
    -Is a drawn wall, so can only be plumb
    -Can contain both Curtain Panels (in rectangular shapes) and system panels
    -Can contain curved upper mullions etc that are actually curves
    -Can be drawn stand-alone since it's just a wall.
    10,362
    06:59 AM
    Quote Originally Posted by Bjorn_K View Post
    Curtain Systems:
    Curtain Wall
    True, except you CAN put non-system panels in Curtain Systems. They will just break if the panel definition (by the curtain grids) are not rectangular, or if the family is not built from an adaptive component template.
  1. Open joint in glass guardrail made with curtainwall system
    By mthurnauer in forum Architecture and General Revit Questions
    Last Post: August 8th, 2016, 06:30 AM
  2. Curtain System - Mullions out of line
    By R-Construction in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: June 10th, 2014, 06:21 PM
  3. Curtain System Tag...Multi-Category?
    By The Dropper in forum Architecture and General Revit Questions
    Last Post: December 16th, 2011, 02:51 PM
  4. Curtain system with Cad imported mesh
    By Lorenzo in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: October 3rd, 2011, 07:00 PM
  5. Replies: 0
    Last Post: September 12th, 2011, 06:13 AM
