Results 1 to 3 of 3
Thread: Filled Region Bug
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    04:24 PM
    Filled Region Bug
    So, basically, I'm creating a few simple drafting views of typical block conditions. Namely, pilasters. Very simple. I'm just using a top view CMU detail item, and dropping a filled region on top of it to show where to fill the cells and add rebar. Very simple stuff.
    No matter what I do for display order, I can't see the filled region. However, it prints correctly. Anyone else experiencing this?
    This worked in 2012, but not in 2013. Also, when I upgrade a 2012 project, it doesn't work any more.
    Attached Thumbnails Attached Thumbnails Filled Region Bug-cmu-preview.png   Filled Region Bug-filled-cmu-cells.png
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,567
    02:24 PM
    Only one the the stupid things about filled regions.
    dzatto's Avatar
    December 9, 2010
    5,234
    04:24 PM
    Yep. For a workaround, I did find that it shows in wireframe. Of course, everything shows in wireframe. But, at least you can see where you added your filled regions.
  1. Filled Region - Category?
    By brinxb in forum Architecture and General Revit Questions
    Last Post: December 11th, 2015, 04:12 PM
  2. Filled Region on sheet.
    By Severnik in forum Tutorials, Tips & Tricks
    Last Post: September 22nd, 2015, 11:14 PM
  3. Filled region elevation
    By sweb in forum Structure - General Questions
    Last Post: October 28th, 2011, 02:44 PM
  4. Filled Region
    By sink69 in forum Architecture and General Revit Questions
    Last Post: October 20th, 2011, 09:50 AM
  5. filled region anomaly
    By tweg in forum Architecture and General Revit Questions
    Last Post: October 11th, 2011, 06:49 PM
