Results 1 to 2 of 2
Thread: Find and replace
    August 7, 2011
    7
    05:20 AM
    Find and replace
    Created original metal stud .rfa with a structural
    framing rft now want to find and replace all with a new
    Structural column rfa?
    Moderator LeanneZ's Avatar
    December 8, 2010
    Charlotte, NC
    761
    07:20 AM
    with the information you gave us, you're not going to be able to do it.
    Since you stated your metal stud family was created as a Framing member, you can only swap it for another framing member.
    Even if you edit your metal stud family to become a Column family (which won't work anyway; you'll get an Invalid Family Category error,) you're still not going to be able to switch out a framing family for a column family. Once you click on the Framing family, you're only going to be able to change it to another framing family.
    Unless you have more information about these families and what your intention/need is, your request cannot be done.
  1. Replace tilet block with title block
    Last Post: May 4th, 2012, 09:48 PM
  2. Replies: 0
    Last Post: February 28th, 2012, 10:45 PM
  3. cant find libraries
    By joewallace in forum Architecture and General Revit Questions
    Last Post: September 10th, 2011, 09:40 PM
  4. Autodesk Find and Replace
    Last Post: July 12th, 2011, 03:45 PM
  5. You will find the use of it...
    By jbenoit44 in forum Tutorials, Tips & Tricks
    Last Post: February 9th, 2011, 02:44 PM
