Results 1 to 4 of 4
Thread: Upon Room tag command all linked levels needlesly refreshed.
    April 24, 2012
    2
    07:26 AM
    Post Upon Room tag command all linked levels needlesly refreshed.
    Background:
    I have linked in every level of the multi-storey project I am working on. However I cannot use linked views to show the room tags.
    Instead I need to add the tags in the file that is linking(the documentation file) to the file where the modelling is performed.
    Problem:
    The file where the documentation is performed refreshes every (11) levels each time a room tag is added, it can take 5 minutes to perform the command and 5 minutes to cancel the transaction. Is there a Revit setting, option etc. to prevent this?
    regards,
    Sisyphus
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    03:56 PM
    What do you mean by the file "refreshes every level"?
    Do you mean you have 11 Views open and they all re-paint?
    If so, maximize the level View into which you are placing your Tags, and then pick Close Hidden Windows from the View Tab.
    April 24, 2012
    2
    07:26 AM
    Hi Dave thanx for the reply!
    Pardon my lack of clarity, to reply to your answer, it's not a matter of closing opened views (there is only one view opened), I have a file that has many separate models linked into a federated file. The status bar on the bottom right of the Revit GUI, is displaying it's progress through all the links, even though they are lower levels of the fed file, they are being updated and can take up to 5 mins approx. to refresh before a room tag can be added to the room in that view.
    Cheers
    January 10, 2011
    St Paul, MN
    2,980
    03:56 PM
    Sounds like a good use for Worksets.
    I'd put each Link on it's own Workset. Then you can Close the Worksets for the floors you're not working on. I would think that would speed up the process.
  1. Specialty Equipment in Room but not Room Aware
    By GMcDowellJr in forum Architecture and General Revit Questions
    Last Post: January 26th, 2012, 07:36 AM
  2. Adding Room / Room Tag too Linked models
    By Raigoki in forum Architecture and General Revit Questions
    Last Post: January 9th, 2012, 01:56 PM
  3. space w/ room name & number of linked arch model
    By Ning Zhou in forum MEP - General
    Last Post: November 23rd, 2011, 04:41 PM
  4. Room Calculation Types accesible through linked models?
    Last Post: June 26th, 2011, 01:15 AM
  5. Is there a stretch command??
    By Sporty in forum Architecture and General Revit Questions
    Last Post: March 10th, 2011, 06:28 PM
Tags for this Thread
