Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Like Tree6Likes
Thread: Walls with no phase?
  1. #11
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,141
    05:37 PM
    Quote Originally Posted by JeffH View Post
    You could just cut and paste the walls back to the same position. This will effectivly delete and recreate the walls. It will aslo "re-register" them to the database. they will probably pick up the phased created parameter as they come back into the database.
    I can copy them but can't delete them in the Legend phase view. I can however do this in a regular (new construction) view and it seems to resolve the issue for the moment.
  2. #12
    January 9, 2019
    1
    09:37 PM
    Hey, this same problem happened to me and this is the only forum post on the entire net that I could see facing the same problem!
    The problem is that sections of a stacked wall were showing up in all phases as they had none for both created and demolished parameters. If anybody comes to this post looking for a solution, I have found one!
    Simply change the phase created on the entire stacked wall to something else (in my case to existing), and then back to the phase you want it and it seems to sort out the phasing problems. Something about when you change the build up of the stack after placing the wall, breaks the phasing in that area until its reset through this method!
    Hope that is a simple enough fix!
    DaveP, cellophane and willsud like this.
  1. Filtering by Phase
    By Lambolica in forum Architecture and General Revit Questions
    Last Post: February 22nd, 2012, 02:02 PM
  2. Stacked walls vs multiple walls
    Last Post: January 27th, 2012, 04:05 PM
  3. Phases - Existing/Phase 1/Phase 2 - Braced Frame Elevations and such
    By LeanneZ in forum Structure - General Questions
    Last Post: November 11th, 2011, 12:57 PM
  4. Demolished walls obscuring new walls
    By anthonyB in forum Architecture and General Revit Questions
    Last Post: November 7th, 2011, 07:34 PM
  5. Phase hatches
    Last Post: August 16th, 2011, 10:59 PM
