Page 9 of 9 FirstFirst ... 56789
Results 81 to 84 of 84
Like Tree54Likes
Thread: Best Practice For Interior Partition Types
  1. #81
    January 5, 2012
    Dallas
    11
    03:43 AM
    I am running into a serious issue and need your assistance. I want to use view filters to graphically represent fire ratings, so I can limit the number of wall types. The only issue is that fill pattern orientation only works at the COARSE detail level. Do you graphically represent fire ratings in your walls? Do you set your floor plans to coarse level? I can't imagine that this will show enough detail in my walls. Any thoughts? Maybe you strictly use tags and do not graphically differentiate between rated and non-rated walls?
  2. #82
    December 21, 2010
    Phoenix, AZ
    2,627
    01:43 AM
    Quote Originally Posted by boujou99 View Post
    Refer to a previous post in this thread. It's been discussed elsewhere as well.
    https://www.revitforum.org/architect...tml#post181580
  3. #83
    10,277
    03:43 AM
    Short version: all layers of the walls (including stud layers) must have a cut pattern. But it can be a single line that repeats every 1000 feet. That's what mine is. And the cut pattern must be set to Orient to View, in the patterns dialogue.
    Then it works at medium and fine LOD as well.
    GMcDowellJr likes this.
  4. #84
    January 5, 2012
    Dallas
    11
    03:43 AM
    You guys are fantastic!
  1. Best Practice Phasing Issue
    By Patrick in forum Architecture and General Revit Questions
    Last Post: May 30th, 2013, 08:56 AM
  2. Best Practice for Sheet Notes
    Last Post: March 27th, 2012, 06:03 PM
  3. Best practice using bim workflow
    By r7_human8y in forum Architecture and General Revit Questions
    Last Post: November 29th, 2011, 02:54 PM
  4. Placing beams - best practice
    By DD1 in forum Structure - General Questions
    Last Post: June 25th, 2011, 06:21 AM
  5. View Template Best Practice
    Last Post: May 21st, 2011, 11:18 AM
