Results 1 to 6 of 6
Thread: Notes directly on Sheets
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    09:32 AM
    Anyone see any issues with putting a note directly on a sheet? In ACA, I've always had sheets only for plotting, no annotation goes on them.
    I need to add a note on my structural details that all elevations are from FF. I figured I'd just type it on the sheet itself. Thoughts?
    Member Chadwick17's Avatar
    Fort Collins, CO
    320
    08:32 AM
    In the case where I need general notes on a sheet like that I like to either do a legend or at least group the notes. That way if anything is added on one sheet it will be updated on the others as well. Whatever I can do to help eliminate potential inconsistency between drawings...
    JCM
    JCM is offline
    December 17, 2010
    Pembroke Pines, FL
    571
    10:32 AM
    I have similar notes in my title block family like: "verify all dimensions on field" , "All Elevations are from FF". I have not encountered a problem with this method yet. But I do small residential renovations.
    dzatto's Avatar
    December 9, 2010
    5,234
    09:32 AM
    I was thinking legend as well, but it's such a small note. lol
    So explain the group to me. If I group the note, do I copy and paste the group to multiple sheets?
    Fort Collins, CO
    320
    08:32 AM
    Quote Originally Posted by dzatto View Post
    Correct. I know it is only one note, but in my experience there are always more notes added to that one which is why like to be able to maintain it automatically across multiple sheets. I like the group personally because it can be inserted on both sheets and inside of views. Not that you need the kind of flexibility all the time, but I like having options...
    EDIT: Forget what I said about groups here. Unless you can match the scale closely with the sheet it will come in all garbled. But you can still maintain groups across the sheets but I don't really think there are great advantages between that and a legend.
    dzatto's Avatar
    December 9, 2010
    5,234
    09:32 AM
    Got it. I'll just do a legend.
  1. Predefined values in new sheets
    By Munkholm in forum Third party Add-Ins, API and R&D
    Last Post: December 5th, 2014, 01:42 PM
  2. sheets and revision
    By jbenoit44 in forum Architecture and General Revit Questions
    Last Post: April 22nd, 2014, 07:51 PM
  3. Sending Autodesk our issues with 2012 directly...
    Last Post: May 18th, 2011, 09:27 PM
  4. Legends on Sheets
    By CBukowski in forum Architecture and General Revit Questions
    Last Post: April 9th, 2011, 06:30 AM
  5. Rearranging views onto different sheets
    Last Post: February 11th, 2011, 02:40 PM
