Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By mdradvies
  • 1 Post By cellophane
Thread: Renaming Families en masse
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,190
    11:20 AM
    Is there a quick way to rename families in a project in a quick way? I'm trying to clean up our template and keeping the OOTB content with Sentence Case and our objects with CAPS but the only thing I can find is to do it one at at time. For instance - OOTB walls are Interior - Brick on CMU a wall that was created should be INTERIOR - BRICK ON CMU or INTERIOR- Brick on CMU and I need a space added after interior.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    03:20 PM
    Not that I know off...
    December 21, 2010
    Phoenix, AZ
    2,644
    08:20 AM
    You could rename the RFA files with any of the numerous file renamers out there and then reload them one-by-one (right-clicking over the family in your template and choosing to reload from there).
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    03:20 PM
    Partially true: won't work for system families and isn't really that fast...
    For system families: expand the project browser and change the names there.
    For component families: ditto, use the Case Inc to export all families at once
    cganiere likes this.
    August 9, 2011
    Louisville, KY
    6,190
    11:20 AM
    The Case app looks interesting. Thanks!
    I've got Bulk Rename Utility which is awesome for files. I was hoping there might be something internal for Revit
    June 3, 2015
    3
    11:20 AM
  1. Export the families from one project to another Or how to keep/copy families
    By Yan Naing Bo in forum Structure - Family Creation
    Last Post: May 15th, 2015, 03:53 AM
  2. Phase Renaming
    By mfrietze in forum Architecture and General Revit Questions
    Last Post: October 7th, 2011, 09:00 PM
  3. Unhosted Families versus Unhosted "Work Plane Based" families.
    By Twiceroadsfool in forum Architecture and General Revit Questions
    Last Post: July 25th, 2011, 02:42 PM
  4. Ligne complexes - Réseaux EU,EP,EV - Plan de masse
    By pcamliti in forum Forum Français
    Last Post: June 21st, 2011, 09:58 PM
