Results 1 to 9 of 9
Thread: Flat Pad on Sloped Roof
    December 13, 2010
    79
    02:30 PM
    I'm adding some HVAC units on a sloped roof. I need them to sit level, on a curb, on the sloping roof.
    Is it possible to build a curb family that can sit on the face/plane of the sloped roof (with varied pitches and slopes), and stays level on top?
    If not, what do people typically do for this situation?
    B
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    04:30 PM
    I haven't done it, but couldn't you make a family that hinges on one side and has an angle parameter for the sloped plane? Sort of like a door swing? I bet there's a way to input a pitch instead of an angle. Like 4:12 instead of 18.43 degrees.
    Member SimAll's Avatar
    January 24, 2011
    Australia
    60
    07:00 AM
    I made something like it: solar panel & geyser system. A generic model - roof based will do. I don't know how to change the pitch from degrees to ratio though. Isn't it better to use degrees though when your roof is pitch is in degrees?
    dzatto's Avatar
    December 9, 2010
    5,234
    04:30 PM
    I do mine with pitch though. lol Even when you slope a roof in Revit, you can input the pitch in the properties window. You don't even need to put in the 12, it just knows. So for a 4:12 pitch, I just input 4 and hit enter. It puts the 12 automatically.
    December 13, 2010
    79
    02:30 PM
    Thanks all.
    I was hoping someone had a trick to create a pad that would automatically adapt it's 'bottom' to the roof slope, while the 'top' would always remain level.
    I'll just assume that it can't be done!
    B
    January 24, 2011
    Australia
    60
    07:00 AM
    we have to have some level of "working" on REVIT
    10,343
    04:30 PM
    You have to decide (with Always vertical) if the BOTTOM is level, or coplaner with the roof. Unfortunately, you cant intelligent alter the top from that, aside from parameters with angles in them. My last experiment with trying to put an Always Vertical (shared) family inside a (Roof hosted non vertical) family taught me that the 'Always Vertical' thing is relative to the specific file you put it in, meaning it wouldnt work correctly in the project. It would be "vertical" in the Parent Family. Suckage.
    Typically (as much as i hate to say it) i will tell them to be "always vertical" and handle it with detailing. Because unless you get that set of angle variables dead nuts on, you wont be able to dimension that family off of ANYTHING in a roof plan. So its draft the detailing, or draft the dimensions, LOL.
    August 9, 2011
    63
    02:30 PM
    Quote Originally Posted by B Arch View Post
    Thanks all.
    B
    I was looking for something else and ran across this thread. Doubt you still need this, but someone else might. I created this for my last project, and while the slope isn't an instance parameter or smart to the pitch of the roof, it is editable by creating new families. IOW, the attached file is for a 1/2" per foot sloping roof. There's a formula for "Rise of Slope" that is
    Code:
    (Length * .5) * .083333
    which is 1/2 length of curb / 12, essentially 1/2" per foot slope. To get a 1/4" slope, you'd do
    Code:
    (Length * .25) * .083333
    and so forth.
    It hosts to the roof at the "short" end.
    It was made on the fly and suited our immediate purposes, so be gentle if you find something wrong with it. And by all means, feel free to modify and share what you've learned.
    It has symbolic cricket lines, too.
    Attached Files Attached Files
    Member lost again again's Avatar
    March 10, 2011
    Northern California
    370
    02:30 PM
    (old thread, but) I've recently bumped up against this problem, and my solution for a flat curb was to use a bit of roof sketched to the required size, raised 6" minimum above the main minimally slope roof, then to use the "join geometry" tool to remove the excess "curb" at its intersection with the main roof. It's not a curb family but shows up correctly (although very simply) in any view.
    Attached Thumbnails Attached Thumbnails Flat Pad on Sloped Roof-screen-shot-2015-11-23-2.32.54-pm.png
    Last edited by lost again again; November 24th, 2015 at 04:31 PM. Reason: correction: "join geometry" not cut.
  1. sloped roof connection between two parts
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: May 19th, 2011, 09:50 AM
  2. Sloping pad issue - 2 pads intersecting each other
    By jh75 in forum Structure - General Questions
    Last Post: May 11th, 2011, 02:30 AM
  3. How to Roof Merge/Join to Lower Roof!!
    By crhdesign in forum Architecture and General Revit Questions
    Last Post: April 30th, 2011, 05:48 AM
  4. Roof with different sloping - one roof or individual surfaces?
    By Clogboy in forum Architecture and General Revit Questions
    Last Post: April 9th, 2011, 12:47 PM
  5. Sloped G;azing Material
    By HenryD in forum Architecture and General Revit Questions
    Last Post: January 4th, 2011, 11:51 AM
