Results 1 to 2 of 2
Thread: customizing revit
    mno
    mno is offline
    Junior Member mno's Avatar
    April 12, 2011
    Amsterdam, the Netherlands
    30
    01:08 AM
    customizing revit
    I've seen a post and the wiki-help about the revit.ini file.
    But unfortunately that file doesn't let me change some things I really want to change.
    For example:
    If I copy an object, 'constrain' and 'multiple' are off. If I check one of these boxes they will be checked for this revit-session until I decide to uncheck them.
    I would also like to uncheck the box 'leader' for my tags.
    Is there a file that I can edit where these kind of settings can be changed?
    Thanks,
    Menno
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    11:08 PM
    Not as far as I know... But doesn't that work the same:
    Add Tag > check off leader before first placement and it stays that way the entire session?
    Same with "Tag on placement", changing dimension types, text styles, and so on...
Tags for this Thread
