Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: How can I reproduce a sheet´s layout and similar content in other related projects?
  1. #21
    Orlando, FL, USA
    3,111
    10:22 AM
    Quote Originally Posted by mdradvies View Post
    Alf, you've been awfully quiet through all of this. Has there been any helpful suggestion?
    Sorry, Martijn, yes, I was away from the thread, but tonight I am reading all the replies. Thank you very much, guys. Well, since things had to move quickly at the office, by the time I am reading all these ideas, I had already created the sheets for projects B and C in the hard way, but I still have to do the sheet for project D, so I am going to try your solution, which seems to be a good one, according to the interesting discussion with Aaron. I have some concerns about that copy/paste operation, though... I would not worry if it was a small project with nothing more than the model itself, but this one has some imports and links.. if I had to rebuild all that, things can go wrong, and it would be too much to risk for just trying to save some time... I think the topic deserves some kind of special tool from the Factory, for future releases. I am going to study and try your method with a small pilot project, first.
  2. #22
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    02:22 PM
    Hi Alfredo,
    Which copy/paste? The only copy/paste I do is concerning the views (and view markers). Everything else is just the standard linking operation. I would be interested to know however in how linking and binding a model which already has other models linked would behave. That one I didn't test.
  3. #23
    Orlando, FL, USA
    3,111
    10:22 AM
    ...Which copy/paste? ....
    You´re right. Maybe I should have said the link and bind operation...
    So, in your method, the former project B .rvt file is left behind, and then you create a new project B based in the template?
  4. #24
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    02:22 PM
    jep. that's the idea. But again, I have no clue on how this responds to a link-in-a-link situation. I know it works surprisingly well with "single-level" projects. But if it means you loose the links in project b, then it wouldn't be very helpful.
  1. Under floor mechanical layout
    By actor in forum MEP - General
    Last Post: August 8th, 2011, 02:47 PM
  2. Custom content vs. manufactures content & File locations
    By Nate L. in forum Architecture and General Revit Questions
    Last Post: May 16th, 2011, 05:55 PM
  3. How to dimension typical (or very similar) floors in a tower?
    By Alfredo Medina in forum Architecture and General Revit Questions
    Last Post: April 19th, 2011, 10:29 PM
  4. Service Layout
    By theshell07 in forum Architecture and General Revit Questions
    Last Post: March 1st, 2011, 01:49 PM
  5. Sheet just became a Detail View, but still listed in Sheet List
    By LeanneZ in forum Architecture and General Revit Questions
    Last Post: February 25th, 2011, 09:25 PM
