Results 1 to 9 of 9
Thread: segment section w/ scope box
    July 20, 2011
    685
    11:46 AM
    scope box is a great tool but seems having quite a few issues, for instance, after rotate project or true north, i have to recreate scope box unless someone can tell me i don't have to.
    now i encountered another issue, i have segment section directly cut through staircase, i can see that staircase untill i applied scope box, if i change that segment section back to normal section, then that staircase show up again, i mean in section view.
    i don't know if it's scope box issue, or staircase issue, anyone had similar case before?
    July 20, 2011
    685
    11:46 AM
    i did some test, see attached JPGs, seems only one of these 2 cases works, looks like a bug to me, or am i missed something?
    Attached Thumbnails Attached Thumbnails segment section w/ scope box-20120105rfo_2.jpg   segment section w/ scope box-20120105rfo_1.jpg
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,553
    06:46 PM
    could you post the sample project? Not seeing this behaviour...
    July 20, 2011
    685
    11:46 AM
    see attached RVT, you cannot see staircase in section 1.
    Attached Files Attached Files
    Kingdom of Denmark
    4,142
    08:46 PM
    Very weird indeed :confued:
    You should send this file to Autodesk Support - Something is very messed up in the file as far as I can tell.
    July 20, 2011
    685
    11:46 AM
    happy new year Klaus!
    file should be OK as i created that new file w/o using any template in order to reduce file size, you can try create new file using normal or default template.
    looks like a bug to me.
    Kingdom of Denmark
    4,142
    08:46 PM
    Happy New Years to you too!
    Tried to replicate the behavior on a blank file but couldn't - Which is why I suggested to have Autodesk Support looking at it.
    February 1, 2011
    United Kingdom
    96
    07:46 PM
    I think I have figured out what the issue is..have a look at this.
    Split Segment Section and Scope Box
    Member Hirvio's Avatar
    March 8, 2011
    Zagreb, Croatia
    243
    08:46 PM
    I ran into this problem yesterday. Prior to plot everything to PDF for delivery, I turned scope box on several sections and ruined all split sections . Luckily it was plot on pdf only...
    So today, I tried to recreate this situation and came to this conclusion - similar as Rahul.
    When scope box is applied to split section, near clip will occur, beginning at the plane in which the first part of section mark was drawn - no matter is it drawn form left to right or vice versa. Look at the attached example, section is drawn from right to left for this purpose. Version is 2011.
    segment section w/ scope box-section-scope-1.jpgsegment section w/ scope box-section-scope-2.jpg
  1. Replies: 0
    Last Post: December 12th, 2011, 11:15 AM
  2. scope box and rotate project north
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: September 2nd, 2011, 06:04 PM
  3. Grid extension past scope box
    By John McCamont in forum Architecture and General Revit Questions
    Last Post: August 30th, 2011, 11:21 PM
  4. Segment Dimension Leader Visibility?
    Last Post: May 23rd, 2011, 10:17 AM
  5. CAD Import - smooth segment edges
    By tvatvn in forum Architecture and General Revit Questions
    Last Post: May 17th, 2011, 10:08 PM
