Results 1 to 8 of 8
Thread: Default Position of Door Tags (or any tags for that matter):
    February 3, 2011
    London, Ontario
    397
    01:47 AM
    Hey Guys,
    Wondering if anyone knows of a way to "preset" the default position of a door tag. Seems to snap by default to the center of the door (geometry in the family), but it would be nice to have it automatically snap to the center of the door leaf...
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,527
    10:47 PM
    Quote Originally Posted by Jj Mac View Post
    Hey Guys,
    how would the tag know which leaf to center in if you have a pair of doors?
    December 21, 2010
    Phoenix, AZ
    2,644
    10:47 PM
    Tags default to the intersection of origin reference planes.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    05:47 AM
    Quote Originally Posted by Dave Jones View Post
    If it's a nested components with 2 leafs in it, it needs to center between the leafs.
    If both leafs are nested separately, they need to be tagged separately...
    But I think the OP means that the placement of tags should follow the intersection of the refplanes labeled "Defines Origin"...
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    3,021
    12:47 AM
    There are two Reference Plane in the Door Family (and the Tag family, for that matter) that have the "Defines Origin" property set to true.
    The intersection of those two Planes defines where the Tag goes - kind of like how a Room Tags goes to the "X" of a Room.
    You can't really mess with those Planes, though, because they define other things like how the Door family flips.
    There's been a long-standing Wish-List item to allow us to specify where aTag would go, but - no action on that yet.
    Dave Jones's Avatar
    4,527
    10:47 PM
    Quote Originally Posted by mdradvies View Post
    maybe? I think that this is what the OP meant
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    05:47 AM
    Well, to do that, you need to make the door leafs two separate families with the center ref plane defining origin... Then tag the door leaf, which is quite doable IF:
    create a custom shared text parameter. Link it to the parent ootb Mark parameter. The custom parameter now mimics the Mark parameter from the parent door family.
    create a door tag which reads the custom parameter and tag the leaf instead of the entire door.
    Done
    February 3, 2011
    London, Ontario
    397
    01:47 AM
    Thanks for all the replies everyone,
    This is what I was affraid of - that it defaulted to the origin and that screwing around with that, would defiantly not be a good thing. This was more of a do-dilligence question anyway, so...
    I think we defianlty need to have the ablilty to definte a seperate "tag origin" in all families. And also a leader start origin in all annotation families. That would be the cat's wiskers.
    Thanks again guys!
    Happy Holidays!
  1. general question re: door tags
    By jmolyneaux in forum Architecture and General Revit Questions
    Last Post: October 27th, 2011, 06:30 PM
  2. Area Tags
    By redmonki in forum Architecture and General Revit Questions
    Last Post: October 10th, 2011, 06:47 AM
  3. Dimensions like Tags
    By gaby424 in forum Tutorials, Tips & Tricks
    Last Post: August 16th, 2011, 07:44 PM
  4. Get your tags out for the lads...
    Last Post: June 29th, 2011, 10:53 AM
  5. Elevation Tags
    By SimAll in forum Architecture and General Revit Questions
    Last Post: April 12th, 2011, 12:03 AM
Tags for this Thread
