Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Like Tree4Likes
Thread: Room Tag With Overall Dimensions
    Member Wadeshuey's Avatar
    January 3, 2011
    Fontana CA USA
    128
    02:31 AM
    Has anyone found a good way to get the room tag to show up with overall dimensions?
    If so I can't figure it out.
    Example:
    101 Room name
    15' x 16'
    Kingdom of Denmark
    4,203
    10:31 AM
    It´s a question that pops every now and then...
    Unfourtunatly there´s no great way to deal with it, besides manually entering the dimensions. (Custom instance based parameters)
    Revit is not repporting the dimensions, and even if it did, what should it repport for rectangular, u-shaped or even triangular rooms ?
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    09:31 AM
    Can't be done, for the exact reasons Munkholm stated.
    There is a workaround though (which I use for checking minimum required floor areas in the Building Codes):
    Create a Generic Fase Based Family.
    Create the form needed (I have forms for triangular, rectangular, 5 corners, u- and l-shaped) in model lines and place instance parameters as a dimension.
    create a tag which reads these parameters.
    when needed, place this family and stretch or align these boundary lines. place the tag near the room tag and you sort of have the result you want.
    uaifestival and cganiere like this.
    January 3, 2011
    Fontana CA USA
    128
    02:31 AM
    That is not a bad idea! Thanks
    JCM
    JCM is offline
    December 17, 2010
    Pembroke Pines, FL
    571
    05:31 AM
    After reading this post I thought I saw something similar somewhere, so I checked my Internet History (very looong!) and found a post from Revit Rocks
    The solution given there has its limitations but it's along the same lines as Martijn suggests
    Junior Member Matt Gienger's Avatar
    November 30, 2015
    Canada
    16
    02:31 AM
    This is exactly what I've been looking for. Thanks everyone!
    Man, it's a little sad how ecstatic I am when I find little tricks like this.
    Cheers
    December 21, 2010
    C.LONDON
    4,343
    09:31 AM
    Nothing to add save no one ever talks about OOTB Room Report feature - and yet (for me) it remains one of the few truly promising (yet so terribly underdeveloped) functions.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,051
    05:31 AM
    I had to look that up It's pretty neat though, except it doesn't report my windows...
    December 21, 2010
    C.LONDON
    4,343
    09:31 AM
    Like I said, hidden deep and underdeveloped, the tool could be so much more.
    February 2, 2011
    Montreal/Paris
    830
    04:31 AM
    Here's a quick example using Dynamo.
    Basically i looked for the lowest X and Y and write that to a Shared Parameters. So for non-rectangular rooms you will get the largest number.
    https://www.dropbox.com/s/5mhdrt8m4h...mSize.zip?dl=0
    ngoc nguyen likes this.
  1. Locate Dimensions
    By safoulkes in forum Architecture and General Revit Questions
    Last Post: August 16th, 2018, 09:15 PM
  2. No Active Dimensions
    By mark b in forum Architecture and General Revit Questions
    Last Post: May 19th, 2011, 04:13 PM
  3. Locking Grids and dimensions
    Last Post: April 12th, 2011, 03:33 PM
  4. Room Tag with Volume Calculated
    By SimAll in forum Architecture and General Revit Questions
    Last Post: February 4th, 2011, 01:22 AM
  5. Dimensions Keep Getting Deleted
    By W.Neuok in forum MEP - General
    Last Post: December 16th, 2010, 08:23 PM
