Page 5 of 5 FirstFirst 12345
Results 41 to 47 of 47
Like Tree1Likes
Thread: High End Cabinet Families
  1. #41
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    07:51 AM
    Yep, this is all based on the assumtion you use Instance Parameters. Type Parameters don't stretch, even if you want the to.
  2. #42
    10,278
    02:51 AM
    Correct. As for the clarification about Strong/Weak/Not... Thats all Mr. Stafford. He pointed it out to me in case i didnt want to continue with the doubling up thing.
  3. #43
    December 20, 2010
    1,061
    02:51 AM
    On the custom cabinets. I recommend and simple extrusion of the box, then make various Casework "door" families that you can easily assemble multiple configurations with.
  4. #44
    10,278
    02:51 AM
    I definetely agree with nesting the doors. We havent yet, but they are set up so thats the next step. But we model the hole in the carcass as well... Too many of them have partial open shelving or no door, to have them be solid boxes. Once you get one good one built, the rest of the library flies.
  5. #45
    December 8, 2010
    37
    02:51 AM
    So when you detail your millwork, do you nest DC's within the cabinet (section)? Or handle it with drafting views? I'm nesting DC's right now but would like to hear what others do?
  6. #46
    10,278
    02:51 AM
    Quote Originally Posted by Brett View Post
    We use drafting views, but here is how we handle it:
    the drafting views have the detailing drawn, but they have dimensions that all reference fields in a Millwork Type schedule, that lists all of the dimensions for all of the variations of cabinets. The dimensions themselves arent in the drafting views, theyre from the modeled objects. Some Drafting View sections represent more than one piece of content (single door / double door... same section, different cabinet) and they are marked "DETAIL FOR: U01, U02" and so forth.
    We dont bother trying the Detail Component thing since Visibility of pieces and objects in content can not be Scale aware. the cabinets turn to mud very quickly with all of that stuff embedded in them, in a building section. You can handle it with LOD, but i dont like having to View template Casework back down to Coarse just to remove stuff like that, or notch it up to Fine just to get it to show up in details. We use fine for presentations with ornate modeling, and coarse removes a lot of things for computer performance.
  7. #47
    December 8, 2010
    37
    02:51 AM
    In the midst of a smallish healthcare job where I've nested parametric DC's into the millwork. It works just fine and live updates which is nice. Having said that, I initially debated whether to go the drafting view route and will revisit it now. Having drafting views to transfer from project to project is an nice benefit. As you said Aaron, alot of the details are common between different types of cabinets so it makes sense to do it that way. Lighter families is also a plus too.
  1. Auto Cavity End Closure and Continuous Cavities
    By mark b in forum Tutorials, Tips & Tricks
    Last Post: October 4th, 2018, 06:41 AM
  2. stretch end of wall specific dimension
    By t1shep in forum Architecture and General Revit Questions
    Last Post: November 11th, 2015, 11:10 AM
  3. Mmmm High Speed Net
    By Alex Cunningham in forum Out There
    Last Post: April 25th, 2011, 10:26 PM
  4. Beam Wall End Cutback
    By djnelson75 in forum Structure - General Questions
    Last Post: April 19th, 2011, 11:14 PM
  5. Line Based Generic Family-End Points Problem
    By MikeMaloney in forum Architecture and General Revit Questions
    Last Post: January 7th, 2011, 09:02 PM
Tags for this Thread
