Results 1 to 3 of 3
Thread: timber facade question
    August 31, 2011
    159
    08:32 AM
    im trying to create a facade system of timber panelling. i want them to be seperated and at different lengths where some would stop at windows etc.
    what would be the easiest way to do this for a relative beginner.
    i did something similar before but i had every piece of timber a wall and then copied and stretched them etc but im looking for an easier way
    thanks
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    846
    06:32 PM
    If it is a flat and vertical facade, you could maybe try a vertical structural beam system, after first making sure you have profiles for your timber in the project. After the beam system is made, you can move each individually if you wish. Just another use for a method that Mark. B. mentioned for making fences. Never used it on a facade, but there is no reason why it wouldn't work if the facade is straight.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    08:32 AM
    Or go with a curtain wall with custom mullion profiles and no panels. You can edit profile to create openings for windows and doors.
  1. Facade refurbishment project
    By Hirvio in forum Architecture and General Revit Questions
    Last Post: November 17th, 2011, 10:13 AM
  2. How to cut the top of a 4 x 4 timber post on an angle?
    By wjnaim in forum Architecture and General Revit Questions
    Last Post: July 23rd, 2011, 10:43 PM
  3. Family content for timber frame elements
    By jorge in forum Architecture - Family Creation
    Last Post: July 19th, 2011, 06:37 PM
  4. Unfold Facade
    By pfaudler in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 6th, 2011, 07:06 PM
  5. Walls on the floor, facade question
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: April 19th, 2011, 02:56 AM
