Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By jbenoit44
Thread: Creating String Lights
    Member safoulkes's Avatar
    Illinois
    146
    07:36 PM
    Hi!
    I've been tasked with creating a nighttime rendering of a pavilion type structure that will be lit with hundreds of string lights. So I am here looking for strategy for string light mass production. I can create the light family, no problem. My problem is finding a way to array that family at even intervals along a catenary arch. Has anyone seen a light family like this anywhere? Any ideas that could make it manageable?
    Thanks for your help.
    Kingdom of Denmark
    4,200
    02:36 AM
    You could reverse engineer the family I posted here, to see how the array could be done.
    And maybe the http://www.revitforum.org/rendering-...revitdeer.html will also provide some inspiration
    Nantes, France
    1,380
    02:36 AM
    I wanted to play with some AC tonight, so I was thinking of a chord to be a placeholder for your lights.
    Attached, a quick mockup of what I'm thinking at.
    3 clicks to put in the project then you have to place your light family on faces, they will move along. Nesting maybe?
    AC chord follows the columns if they are moved, and distance between points is adjust accordingly.
    the good part is that the points in the AC family could be driven by a parameter, and some math I guess. The bad part is that arrays are not available in AC families. But I know there are some workaround, should ask Zach.
    There's some work left....hope it helps.
    PS: first time with lights families, so no high value inside....
    Attached Thumbnails Attached Thumbnails Creating String Lights-string-light-rfo.jpg
    Attached Files Attached Files
    crodr25 likes this.
    Illinois
    146
    07:36 PM
    Thanks guys - these are incredibly helpful examples. I have never worked with Adaptive Components before so I am going to do some research on that before I get into that family. Thanks for your help, I’ll let you know how it goes from here.
    December 13, 2016
    1
    01:36 AM
    Family ac_string lights _01.rfa
    Hi Mate once this family is in the project how do you use it again? its not showing up in anywhere and it wont load back in either? im stuck please help
    Quote Originally Posted by jbenoit44 View Post
  1. Building Coder: String Search ADN Plugin of the Month
    Last Post: October 27th, 2011, 12:15 PM
  2. Replies: 0
    Last Post: October 27th, 2011, 11:15 AM
  3. Explain String
    By kmaggiee in forum MEP - Family Creation
    Last Post: July 19th, 2011, 05:15 PM
  4. Red lights; what category?
    By Gordon Price in forum MEP - General
    Last Post: June 13th, 2011, 01:29 PM
  5. Lights on a sloped ceiling
    By Topdraw in forum Architecture and General Revit Questions
    Last Post: May 18th, 2011, 02:31 PM
