Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Robert Roffe
Thread: White window in grey walls
  1.    #1
    May 31, 2018
    Quebec, Canada
    39
    03:45 PM
    Hi guys,
    is there a way to have my opennings white in my grey walls? I looked into visibility but it seems we cant add a pattern inside the different components of the window so how would you do it?
    thanks for your help guys!
  2.    #2
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    10:45 AM
    How are you making your Walls show as grey?
    I'm guessing they're Existing & you've got a Graphic Override set so extincting shows grey. If that's the case, then the Existing Window is going to be grey, too.
    If that's not it, there are a million other possible reasons.
  3.    #3
    May 31, 2018
    Quebec, Canada
    39
    03:45 PM
    yeah I have set the walls grey it is for evacuation plan so I want all walls grey then all windows white in it !
    thanks for your reply sir!
  4.    #4
    July 7, 2011
    Rotterdam, Holland
    1,233
    05:45 PM
    You can most likely go with a filter there. Filter out your walls and make them grey and the windows will stay white.
  5.    #5
    September 19, 2017
    Seattle, WA
    43
    08:45 AM
    It looks like you have both the cut pattern and the surface pattern of walls set to gray. If you don't override the surface pattern, you should get the results you want. That is, unless there's a specific reason the surface pattern of the walls needs to be gray in plan.
    d.stairmand likes this.
  1. Shades of Grey: A WINDOW INTO TUSCANNY
    By Shades of Grey in forum Blog Feeds
    Last Post: April 1st, 2018, 04:16 PM
  2. White as Grey in Elevation - Drywall Material Issue
    By Nonna in forum Architecture and General Revit Questions
    Last Post: April 25th, 2017, 02:09 PM
  3. Color Fill Legend - Transparent hatches have grey background not white..
    By josephpeel in forum Architecture and General Revit Questions
    Last Post: December 15th, 2016, 04:28 PM
  4. Logo experimentation - DWG can import as off-white, but not pure white
    By kescr in forum Architecture and General Revit Questions
    Last Post: December 24th, 2014, 02:15 PM
  5. White Walls
    By 3drulez in forum Rendering and Gallery
    Last Post: July 7th, 2011, 06:15 PM
