Results 1 to 1 of 1
Thread: Levels Not Hidden in Section with Break View
  1.    #1
    New Member dcnilsson's Avatar
    November 16, 2015
    Atlanta, GA
    2
    10:46 AM
    I'm having this occur in a file randomly, but with increasing frequency (2019.2, Build 19.2.0.65 which I know is one behind current).
    In a section view, when I use a break to remove the middle portion everything is hidden except for the level markers. Attached is a screen cap of what it looks like. I'm pretty sure this isn't an intended behavior, and it comes and goes. If I join these sections together and split them again, sometimes the levels go away as expected. If I join and split again, sometimes they'll come back.
    If there's something I'm doing to cause this, I can't figure out what it is. It started with an occasional new section view, and has spread to existing sections when I try to edit them. Has anyone seen this before? I've tried searching here and via Google, but I'm not sure what key words would cover this.
    Attached Thumbnails Attached Thumbnails Levels Not Hidden in Section with Break View-level-marker-issue.png
  1. Wall Section Break View
    By Cesimard in forum Architecture and General Revit Questions
    Last Post: May 17th, 2018, 09:56 PM
  2. View break is masking surface pattern
    By lwhiteman88 in forum Architecture and General Revit Questions
    Last Post: April 23rd, 2015, 04:18 PM
  3. Hidden line view. Hidden lines showing.
    By redmonki in forum Architecture and General Revit Questions
    Last Post: July 27th, 2013, 09:12 AM
  4. Levels in Section View
    By MugmaMan82 in forum Architecture and General Revit Questions
    Last Post: June 26th, 2013, 11:10 AM
  5. elevations ~~ can I draw a section and have it to break at an angle?
    By sepideh in forum Structure - General Questions
    Last Post: October 15th, 2012, 01:17 PM
