Results 1 to 2 of 2
Thread: Revit links greyed out
  1.    #1
    Lurker
    June 11, 2019
    1
    11:56 AM
    I have opened a revit file from the engineer - saved it as a central model & am on the opening page - going into manage to add in the revit links and all items are greyed out. Have tried to detach from central with same results. Any suggestions?
  2.    #2
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    10:56 AM
    You can't add new Linked Revit models if you're in a Drafting View
    Try opening a Floor Plan View. You should be able to use the Manage Links dialog from there.
  1. Hatch greyed out
    By Redrickyd in forum Architecture and General Revit Questions
    Last Post: October 2nd, 2018, 09:40 PM
  2. Help - Revit worksets management in links of links
    By trimtab in forum Architecture and General Revit Questions
    Last Post: October 12th, 2016, 10:38 AM
  3. Greyed out revit link settings
    By trevorpan in forum Structure - General Questions
    Last Post: September 23rd, 2014, 10:13 PM
  4. Why Sub discipline is greyed out ??!
    By ahmed_hassan in forum MEP - General
    Last Post: April 10th, 2014, 03:07 PM
  5. Model greyed out in 3d Revit 2011 can we make it normal ?
    Last Post: March 16th, 2012, 12:23 PM
