Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Damo
Thread: Override Graphics in View ambiguity
  1.    #1
    Member Damo's Avatar
    March 2, 2011
    London, UK
    130
    04:20 PM
    I have a building where sight-lines from established windows are critical. To see where my building might be clipping the sight-line I modeled an in-place extrusion, gave it the glazing category.
    South elevation, I change the graphics override as follows (Override Graphics in View -> By Element):
    View looks like it should do:
    I go to the north elevation and make the same graphics override, but the element won't change.
    I've tried the same with a section looking in the same direction as the successful South Elevation, but again the element doesn't change.
    All views are the same phase (New Construction).
    Both elevations have the same View Template applied.
    I cannot figure out why the same element isn't responding the same in both views.
    Any opinions or guidance?
    Thanks
  2.    #2
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    492
    10:20 AM
    You made the graphics change to the projected lines of the in-place element. Could your north elevation actually be cutting the element? Likewise the section you made is cutting the element so you need to make those same overrides to the Cut section of the element override settings, not the Projection.
  3.    #3
    March 2, 2011
    London, UK
    130
    04:20 PM
    Quote Originally Posted by PatrickGSR94 View Post
    Thanks Patrick, you've hit the nail on the head.
    Moved the elevation cut line outside of the in-place element and... sorted.
    Thank you.
    PatrickGSR94 likes this.
  1. Override Graphics in View By Element
    By Steve_Stafford in forum Architecture and General Revit Questions
    Last Post: September 30th, 2017, 02:53 PM
  2. Visibility Graphics Override help
    By JWelsh1990 in forum Architecture and General Revit Questions
    Last Post: December 16th, 2015, 02:08 AM
  3. Realistic view individual element override graphics
    By ashleye in forum Architecture and General Revit Questions
    Last Post: February 25th, 2015, 11:41 PM
  4. Override graphics of Legend Component
    By cliff collins in forum Architecture and General Revit Questions
    Last Post: November 24th, 2014, 02:17 PM
  5. Override Graphics in View - Filter
    By GStas in forum Architecture and General Revit Questions
    Last Post: April 2nd, 2014, 12:32 PM
