Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Robert Roffe
Thread: Material Takeoff example question
  1.    #1
    June 5, 2019
    3
    12:41 PM
    Hello mates!
    I like to go deeper into the material takeoff managing.
    What brings me here is that I cannot emulate the example that autodesk (Attached image) uses to illustrate the tool, in which there are columns under a single one (components / subcomponents)
    Could you help me?
    Thanks in advance
    Attached Thumbnails Attached Thumbnails Material Takeoff example question-guid-157ef9e8-a98d-4661-999d-9dbd7afe7876.png
  2.    #2
    December 21, 2010
    Phoenix, AZ
    2,601
    08:41 AM
    Looks like they unchecked Itemize Every Instance.
  3.    #3
    June 5, 2019
    3
    12:41 PM
    Quote Originally Posted by GMcDowellJr View Post
    Thanks a lot for your quick reply.
    I tried what you said, but it doesn't seem to work. What I want to do is to have "name, area and volume" inside "Material". The only way I found to achive it is to separate the title in columns and adjust them by hand.
    Anyway, I will keep searching.
    Cheers.
  4.    #4
    September 19, 2017
    Seattle, WA
    43
    08:41 AM
    It looks like they've grouped the name, area, and volume headers. See this Autodesk help article for more information.
    https://knowledge.autodesk.com/suppo...65C00-htm.html
    JeffH likes this.
  5.    #5
    June 5, 2019
    3
    12:41 PM
    Talking
    Quote Originally Posted by Robert Roffe View Post
    That works perfectly...
    Excellent man. Thank you so much !
    Cheers
  1. Quantities or Material Takeoff, material costs and thermal values
    By alfakappa in forum Architecture - Family Creation
    Last Post: August 22nd, 2014, 10:34 AM
  2. Material Takeoff
    By gdoherty0102 in forum Structure - General Questions
    Last Post: September 25th, 2013, 06:39 PM
  3. get Ramp material info. for material takeoff purpose
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: April 15th, 2013, 07:02 AM
  4. Material Takeoff
    By anjali in forum Architecture and General Revit Questions
    Last Post: July 30th, 2012, 01:37 PM
  5. Material takeoff
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: August 4th, 2011, 02:22 PM
