Results 1 to 5 of 5
Thread: Open dialog columns
  1.    #1
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    10:43 AM
    Open dialog columns
    Does anyone else lose the columns in their Revit Open dialog box?
    Seemingly at random, I lose the Date Modified and/or the Size columns in my dialog.
    Haven't determined any pattern to when or why this happens, but tend to like to sort by Date a lot, and I like to see the file size, so it's irritating to have to continually right-click and restore those columns
  2.    #2
    December 21, 2010
    Phoenix, AZ
    2,601
    08:43 AM
    Yes... but solidarity is all I got for you.
  3.    #3
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    492
    10:43 AM
    I just noticed that my Save As dialog shows date modified, type and size; but my Open dialog box only shows Date Modified and Type. Load Family has date, type and size. But then Insert Views From File only shows the file/folder name with no other columns. So maybe separate column settings for each individual type of file access dialog box?
  4.    #4
    Member jsnyder's Avatar
    December 9, 2010
    AUGI Refugee
    347
    08:43 AM
    Yes. I got over it a few years ago. I blame Windows 10.
  5.    #5
    July 10, 2015
    Boise, Idaho
    663
    09:43 AM
    Microsoft is too busy fixing what's not broken to fix what is broken. You can't inflate your budget without a problem to solve. Even if it doesn't exist. But there is no budget to fix things that never should have been broken to begin with.
  1. Open workset dialog to release memory
    By cheinaranta in forum Architecture and General Revit Questions
    Last Post: July 20th, 2017, 06:59 PM
  2. 2017.1 File open Dialog Box - Unwanted BIM-360 icon
    By nddesign in forum Architecture and General Revit Questions
    Last Post: November 8th, 2016, 02:34 PM
  3. Warning dialog box won't open!
    By Parametric Snowman in forum Architecture and General Revit Questions
    Last Post: April 28th, 2014, 10:02 PM
  4. Warning dialog will not open
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: April 14th, 2014, 03:21 PM
  5. Can't Save - Dialog Open
    By LKeyser in forum Architecture and General Revit Questions
    Last Post: February 15th, 2013, 07:04 PM
