Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Like Tree5Likes
Thread: Multiple viewports - cant individually scale
  1.    #1
    June 10, 2019
    2
    03:45 PM
    Hello,
    Im trying to add a viewport to an existing sheet which I want to scale differently, however every time I bring the view in and place it on my sheet and change the scale, everything else changes with it, it wont let me do it on its own, I assume somewhere a box is checked but as its not my RVT file I dont know what Im looking for and Im fairly new to Revit, I've managed it at home on my own full student version 2018 but cant seem to manage it on the works 2019 Lite version - can anyone help.
    Cheers
  2.    #2
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    09:45 AM
    What do you mean by "everything else changes with it"?
    That's the way Revit scaling works. All of the Annotation scales together.
    Or, perhaps you mean all of the other Views on the Sheet change scale too?
    IF that's the case, that tells me you're changing the scale in a View Template, not an individual View. If that's the case, you can either change that View's View Template to None, or uncheck the box next to Scale in the View Template
    DaveB71 likes this.
  3.    #3
    June 10, 2019
    2
    03:45 PM
    Yes mate that’s bang on all the other views change, I will try that cheers 👍
  4.    #4
    December 10, 2018
    7
    03:45 PM
    Hi again
    Ive tried that and it doesnt work unfortunately, what Im trying to do is create a different view of the same floor plan (which is on a view template) but at a different scale and its proving very difficult, can you offer any assistance.
    Cheers
    Dave
  5.    #5
    June 21, 2012
    Tours, France
    982
    04:45 PM
    May you post some screen-shots to better understand your problem?, regards
    DaveB71 likes this.
  6.    #6
    Moderator mark b's Avatar
    NSW Australia
    1,430
    12:45 AM
    Quote Originally Posted by DaveB_71 View Post
    Sounds like the view may have been created as a "Dependent View"
    Try selecting the view in the Project Browser then "Right Click" then select "Convert to Independent View"
    Attached Thumbnails Attached Thumbnails Multiple viewports - cant individually scale-image.jpg
    DaveB71 likes this.
  7.    #7
    December 10, 2018
    7
    03:45 PM
  8.    #8
    December 10, 2018
    7
    03:45 PM
    Ive even just tried to create a new template from the current view after highlighting the view in red and greying out everything else but that didnt work, Im baffled?? Is it to do with the fact its the same floor plan?
  9.    #9
    June 21, 2012
    Tours, France
    982
    04:45 PM
    Did you already try the solution that Mark_B proposes? ;
    I guess you can create a brand new copy of that view and try to remove all view templates, check if isn't a dependent copy as suggested above
    DaveB71 likes this.
  10.    #10
    December 10, 2018
    7
    03:45 PM
    Yes Andres Ive tried that it doesnt seem to work, it must be easier than this is proving to be, anymore suggestions
  1. Individually Editable Text/Labels in Generic Annotations
    By denden in forum Architecture and General Revit Questions
    Last Post: July 20th, 2017, 02:56 PM
  2. Replies: 0
    Last Post: September 8th, 2015, 04:45 AM
  3. Replies: 0
    Last Post: May 29th, 2014, 06:45 AM
  4. Revit OpEd: Show When Multiple Viewports
    Last Post: October 27th, 2011, 05:15 PM
  5. scale label with multiple views on sheet
    By jbenoit44 in forum Architecture and General Revit Questions
    Last Post: July 1st, 2011, 12:20 AM
