Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By PatrickGSR94
Thread: Contour issues..
  1.    #1
    November 19, 2015
    19
    03:07 PM
    Contour issues..
    Can anyone tell me I am not getting the primary contours on the whole increment? (Topography is over an image of a site plan from a past project.)
    T.I.A.
  2.    #2
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    348
    03:07 AM
    1 - Go into your "Site settings" & Adjust the Topo Interval
    2 - Make sure your "Secondary" Contour Object Category is on, not just the "Primary"
    If you can't find these - Do a Google Search
  3.    #3
    November 19, 2015
    19
    03:07 PM
    d.stairmand - it took some tweaking bit by bit, (and although I have secondary contours selected and set to appear - they don't), but it is good enough to pass muster. Thank you!
  4.    #4
    February 24, 2011
    Auckland
    348
    03:07 AM
    No worries Dozing - Glad I could help
    Topos are a nightmare at the best of time, especially when your trying to find out why they aren't doing thing they are meant too
  5.    #5
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    492
    10:07 AM
    The best way I have found to create toposurfaces is by using the surveyor's original points file, and NOT using their contour lines. Why? Because their contour lines were already generated by their program triangulating all the survey points to calculate the contours. I would rather Revit do its own triangulation from the original point data. In most cases I get a more accurate surface. I usually still have to add points to "force" Revit to not erroneously connect contours lines, especially for things like drainage swales, but it's still a lot less work to start with the points file instead of creating topo points from the survey contour lines.
    d.stairmand likes this.
  6.    #6
    February 24, 2011
    Auckland
    348
    03:07 AM
    Quote Originally Posted by PatrickGSR94 View Post
    Agree 100%
    Most of the Survey DWG Files we get have a "TIN" Layer that has there Original Points based in a Simple Triangulation Surface
    I pick this layer & then let Revit Interpret the Contours itself based off these Accurate Point
    It can be a bit of a head ache when telling a Architect that the Contours will be different than that of the Survey - As they are both an interpretation of Point from Different CAD Programs
  7.    #7
    July 7, 2017
    Hernando, MS
    492
    10:07 AM
    hm I haven't tried using the TIN layer to generate the points. I usually try to get a points text file from the surveyor, which I convert into the proper CSV file for Revit to understand (usually involves swapping the point coordinate columns from Northing/Easting format to X/Y format, and delete the point number column).
  1. Contour Lines Have Disappeared
    By Ben9465 in forum Architecture and General Revit Questions
    Last Post: December 2nd, 2016, 06:09 AM
  2. change contour labels
    By Davoid in forum Architecture and General Revit Questions
    Last Post: April 13th, 2015, 02:42 AM
  3. Topo contour lines visibility
    By Maddren in forum Architecture and General Revit Questions
    Last Post: November 25th, 2013, 05:39 AM
  4. RAC 2012: Contour labels (STILL) upside down?
    Last Post: October 14th, 2011, 02:28 PM
  5. Contour Problems
    By SimAll in forum Architecture and General Revit Questions
    Last Post: January 25th, 2011, 08:25 AM
