Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Like Tree8Likes
Thread: Soffit Wrapping?
  1.    #11
    December 20, 2010
    1,058
    11:16 AM
    All you have to do is model the soffit to the "face of core" and if both the wall gyp and the ceiling are the same material you won't have the double line.Soffit Wrapping?-soffits.png
    pivoarch and kraftwerk like this.
  2.    #12
    September 24, 2015
    29
    08:16 AM
    Quote Originally Posted by sdbrownaia View Post
    All you have to do is model the soffit to the "face of core" and if both the wall gyp and the ceiling are the same material you won't have the double line.Click image for larger version.
    I tried that. But your confidence and write up there convinced me to retry altogether. And the quirky thing was that if the wall and ceiling were already joined, changing the wall gyp to the same material didn't work, but if I unjoined and then rejoined them, it worked! The order of steps really matters in a lot of things in Revit lol
    Thanks all for the help.
  3.    #13
    December 21, 2010
    Phoenix, AZ
    2,601
    08:16 AM
    That gets rid of the line in section but not in plan/rcp/3d.
  4.    #14
    10,187
    10:16 AM
    Quote Originally Posted by GMcDowellJr View Post
    I dont even use Pick Lines OR do the face of Core, thing.
    When im designing, i almost always model the ceilings first, and do the bulkheads / walls later.
    Then after the bulkheads and walls (which are now coplanar), i edit the ceiling sketches and push the sketch lines in the 5/8".
    Then i use Join geometry.
    Yes, it means that in RCP, two lines exist. But those lines are 5/8" apart. which- even at 1/4"- arent legible through the lineweights that exist for the face of the bulkhead. When lineweights are turned off? Sure, they exist. Thats okay (to me).
    The lines DONT exist in Elevation, since they arent coplanar anymore. Thats way more important to me, since THOSE lines are 4 or more inches apart. And that definitely WOULD show up in any drawing.
    GMcDowellJr likes this.
  5.    #15
    December 21, 2010
    Phoenix, AZ
    2,601
    08:16 AM
    Yeah - agree - the OP was about the lines in RCP.
    I thought I had a way with the GWB turned under the metal stud but I haven't used it in years (not worth the trouble IMO) and when I try and recreate the wall type I'm getting errors.
    edit: I found the wall type in an old project but it doesn't do what I thought it did - probably why I abandoned it 5 years ago! LOL
    Twiceroadsfool likes this.
  6.    #16
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    492
    10:16 AM
    I'm with Aaron on this one. We (or I at least) do the same thing. Although having a sweep at the bottom of a bulkhead wall type sounds intriguing.
  7.    #17
    Coeur d Alene, ID
    4,783
    08:16 AM
    Soffit wall needs to be set to Wrap on ends....but I cheat a bit if my core material is different and offset the ceiling sketch line the thickness of the gyp bd.
    Wraps fine in section and no lines in the RFP.
    But I only do this if there is a section or detail...no point in doing it everywhere
  8.    #18
    May 18, 2011
    Calgary, AB
    401
    09:16 AM
    I second that and doesn't matter what order the join. Ceiling to wall or wall to ceiling.
  1. Steelwork on sloping soffit
    By simon1688 in forum Structure - General Questions
    Last Post: September 21st, 2015, 02:45 PM
  2. pointed roof soffit
    By adamheon in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: November 11th, 2013, 06:39 PM
  3. Gable Soffit Closure
    By kowen1208 in forum Architecture and General Revit Questions
    Last Post: June 25th, 2013, 02:36 AM
  4. Curved Soffit Beam
    By MartinGT in forum Structure - General Questions
    Last Post: May 13th, 2013, 12:10 PM
  5. Tag A Soffit?
    Last Post: June 24th, 2011, 10:06 PM
