Results 1 to 6 of 6
Thread: BimObject showcase marbodal kitchen set
  1.    #1
    June 6, 2019
    Washington DC
    5
    11:33 AM
    Hi all,
    I am trying to add this default kitchen family/group into a project file, however every time I try to load family or group it says
    "The shared parameter "049391e0-c9b7-4d13-bcfb-84c309686c1f" cannot be added with name "Nominal width" and type "Number" because it conflicts with the existing name "Nominal width" and type "Length"."
    It also says that about the height and the width. I have read many forums about deleting parameters but it is not working. I am not sure if i am doing in correctly. I am a novice at revit pls help. Thanks
  2.    #2
    July 7, 2011
    Rotterdam, Holland
    1,233
    05:33 PM
    It looks like there is a parameter Nominal width from the type Number in your family (which in it self is a weird parameter type for a width).
    You have to remove that from your family and make a new parameter from the Length type.
    You can just select the parameter and delete it in your family.
    Oh it looks like that kitchen is a collection of families, and they all have that parameter. That makes it a bit more complicated. To be honest I don;t really know where to begin. You need to find that parameter that is casuing the issue and get rid of it, either in all the families, or in the project.
  3.    #3
    June 6, 2019
    Washington DC
    5
    11:33 AM
    Ok thank you for the quick reply!
  4.    #4
    June 6, 2019
    Washington DC
    5
    11:33 AM
    Other compatible format
    This is kinda a long shot, however is it possible to download a different file type and insert it into my revit project file. My thinking is these parameters will not be there if its not a revit file, or I might be wrong.
    Thanks!
  5.    #5
    July 7, 2011
    Rotterdam, Holland
    1,233
    05:33 PM
    What other file type do you have in mind?
    If you are thinking of importing dwg's then NO !!!
  6.    #6
    June 6, 2019
    Washington DC
    5
    11:33 AM
    Quote Originally Posted by Robin Deurloo View Post
    What is wrong with a dwg file. I have exported dwg to get objects in the past?
  1. Replies: 0
    Last Post: February 3rd, 2017, 05:15 PM
  2. Replies: 0
    Last Post: June 8th, 2015, 03:15 PM
  3. Replies: 0
    Last Post: August 30th, 2012, 11:15 AM
  4. Kitchen
    By muttlieb in forum Rendering and Gallery
    Last Post: January 19th, 2011, 02:48 AM
  5. Kitchen
    Last Post: December 9th, 2010, 07:21 PM
