Results 1 to 2 of 2
Thread: Material Browser Incomplete - Cannot Edit Materials
  1.    #1
    November 27, 2013
    33
    10:43 AM
    All of the computers in my office use the same image, and same deployment to get Revit installed. However on 2 machines, the Materials Browser is popping up in some sort of incomplete version of itself (see image)
    On these particular machines, you can still change what material something is - by selecting from the list of other materials loaded in the project. However, you cannot edit any of the materials, add new materials, or even add libraries.
    • The common materials libraries do appear to be installed, as I found the following folder filled with content:
      C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\2019
    • I checked the computers' display resolutions, and both are set to 100%.
    • I have tried uninstalling Revit and reinstalling Revit on one of the machines, and i had no success resolving the problem.
    Anyone else encounter this issue? What could be causing this?
  2.    #2
    November 27, 2013
    33
    10:43 AM
    I was able to get some help from Barth Bradley over on the Autodesk Knowledge Network forum - The answer to the problem was uninstalling and reinstalling all of the materials libraries for 2018 & 2019.
    For my Revit 2019 - I was able to just re-run the Revit installation (it skipped the revit install itself, but went on to install the materials libraries as part of the process) and fix the problem. But when i tried doing the same for Revit 2018, which was having the same issue, the Revit re-installation did not fix the issue.
    Finding the 2018 Material Libraries as an independently downloadable installation package was difficult - it took a lot of searching to track it down. Eventually, I found links to the content i needed within this Infraworks Knowledge Post.
  1. Incomplete Materials Browser While Remoting In to Desktop.
    By nharburger in forum Architecture and General Revit Questions
    Last Post: April 4th, 2019, 02:18 PM
  2. Problem with Material Browser
    By lee jun ze 1998 in forum Architecture and General Revit Questions
    Last Post: June 26th, 2018, 12:56 PM
  3. New FormIt 360 v12 released today! Materials Browser is AWESOME!
    By Scott D Davis in forum Architecture and General Revit Questions
    Last Post: November 5th, 2015, 12:12 AM
  4. Revit2014 Material Browser
    By rick2771 in forum Architecture and General Revit Questions
    Last Post: January 12th, 2015, 02:31 PM
  5. How to edit a FamilyInstances Materials
    By samz1 in forum Third party Add-Ins, API and R&D
    Last Post: November 5th, 2013, 07:45 AM
