Results 1 to 2 of 2
Thread: Window Family with Design Pressures
  1.    #1
    Lurker
    April 15, 2019
    Orlando, FL
    1
    04:49 PM
    Post Window Family with Design Pressures
    is it possible to apply formulas to window and door families to calculate wind design pressures based on placement of the family on a structure?
  2.    #2
    December 21, 2010
    Phoenix, AZ
    2,601
    01:49 PM
    Not natively. You can add parameters to manually input location, height, etc. You can also use Dynamo to fill in those parameters with a little work.
  1. Window Family Problems
    By sotekt in forum Architecture - Family Creation
    Last Post: September 19th, 2016, 05:05 PM
  2. Convert window family into curtain wall panel family
    By amolese in forum Architecture - Family Creation
    Last Post: January 27th, 2015, 02:20 PM
  3. Family Pop Up Window
    By pivoarch in forum Architecture and General Revit Questions
    Last Post: November 14th, 2014, 03:43 PM
  4. Window Family
    By GStas in forum Architecture - Family Creation
    Last Post: April 21st, 2014, 05:01 PM
  5. Window famility to host a window family
    By JasonWallis in forum Structure - Family Creation
    Last Post: January 30th, 2013, 11:27 PM
Tags for this Thread
