Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Like Tree4Likes
Thread: Detail Component Organization
  1.    #1
    April 14, 2014
    66
    04:50 PM
    How do you organize your detail components? I have thought up a couple systems, but they will all get shot the second you load an OOTB family in. Maintaining an entire library of renamed OOTB detail components is not manageable for a small company like the one I work for. Without any organization, the detail component families quickly become a gigantic mess.
    I'd love to hear any ideas.
  2.    #2
    Member jsnyder's Avatar
    December 9, 2010
    AUGI Refugee
    347
    01:50 PM
    I think there are several threads on the forum regarding this topic, but as a quick answer, we organize them by CSI specification number.
    rosskirby likes this.
  3.    #3
    10,188
    03:50 PM
    Quote Originally Posted by Peter1979 View Post
    Not using the OOTB Detail Components (and/or managing a renamed version of them) is absolutely manageable for a small firm. You are one 40 dollar license of Bulk Rename Utility (and 2 hours of your time) from having it done.
  4.    #4
    January 19, 2012
    327
    03:50 PM
    CSI then for the model content add the Revit Category it's assigned to & maybe 3 other fields. That way as you're in a detailed view you can more easily coordinate what Detail Items to bring in. Do the same with Materials so an assembly with proper materials with proper CSI prefixes can tell you most of the detail outline it needs. Like the cheesy cliches; using CSI #'s is the Synergy between going from Large Scope to Small Scope that does the Heavy Lifting to produce a Win-Win Situation. That's all the cliches I could bear to write so you can convince corporate, lol.
  5.    #5
    April 14, 2014
    66
    04:50 PM
    Are there any tutorials for such a process and any specific programs you would recommend?
  6.    #6
    10,188
    03:50 PM
    Bulk Rename Utility. 40 dollars.
    Drop families in folder by folder. Bulk select in the UI. Rename. Repeat til the library is done.
    Super fast.
    Andres Franco and d.stairmand like this.
  7.    #7
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    03:50 PM
    We use a freebie called Advanced Renamer.
    You can add or remove characters, or replace one string with another, even do things like swap the first word and the second (first name, last name to last name, first name)
    It also lets you preview your changes before you apply them.
  8.    #8
    Gold Coast
    2,619
    06:50 AM
    +1 Bulk renamer. I also have a few dynamo scripts to work on families & type names within a project.
  9.    #9
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    334
    08:50 PM
    Total Commander also does most of these things. Plus a ton of other file management chores.
    Nurlan likes this.
  10.    #10
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,141
    04:50 PM
    I would recommend running a few trials before you hit the office standards folder. Bulk Rename Utility is amazing, but there is no undo function, and you can completely hose a directory in about 5 seconds if you aren't paying attention. Otherwise - what Aaron said.
  1. Detail Component vs Line Based Detail Component
    By d.stairmand in forum Architecture - Family Creation
    Last Post: July 23rd, 2017, 03:52 AM
  2. Creating Detail Component
    By Yan Naing Bo in forum Structure - Family Creation
    Last Post: April 25th, 2012, 09:21 PM
  3. Detail Component Creation from CAD
    By cellophane in forum Architecture - Family Creation
    Last Post: February 1st, 2012, 07:02 PM
  4. Replies: 0
    Last Post: December 7th, 2011, 02:15 AM
  5. Detail Component
    Last Post: December 14th, 2010, 10:42 PM
