Results 1 to 2 of 2
Thread: Formula in titel block
  1.    #1
    January 19, 2017
    11
    09:06 PM
    I'd tried to make a formula in a title block, but I'm not quite sure if it's possible?
    I've made two shared parameters and tried to divide them by each other.
    Them I loaded it into a projekt and just godt a "?" instead of the result?
    Am I doing something wrong, or is this not possible?
    I'll hope someone can help me
  2.    #2
    Coeur d Alene, ID
    4,736
    12:06 PM
    Did you load the same shared parameters into your project and assign them to sheets?
  1. Replies: 2
    Last Post: November 18th, 2016, 01:24 PM
  2. Replace tilet block with title block
    Last Post: May 4th, 2012, 09:48 PM
  3. Schedule formula (is there a formula expert in the house?)
    By John McCamont in forum Architecture and General Revit Questions
    Last Post: September 9th, 2011, 09:50 PM
  4. Revision block and title block
    By soboyle in forum Architecture and General Revit Questions
    Last Post: April 25th, 2011, 09:22 AM
  5. Half block reveal with full block above
    Last Post: February 22nd, 2011, 03:28 PM
Tags for this Thread
